Replacing air filter on EVOMS V-Flow intake system
Old Feb 19, 2006 | 02:50 PM
RT7's Avatar
RT7
Show-N-Go like J-Lo Mofo
RT7 is infamous around these parts
Is there a better way of replacing the EVOMS air filter without removing the entire kit (filter, air box, tubing, etc.)? It's all snugged in and no room to move around the filter. I'm replacing the existing filter with the cotton filter.
TIA.
Old Feb 19, 2006 | 03:42 PM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
I don't know of any way except by taking the whole box out.
Old Feb 19, 2006 | 03:43 PM
sharkster's Avatar
TIA.
Hey bud... you really do have to pull the box out to do it Otherwise it'll look more like a scrolled up bit of paper when you're done...
Old Feb 19, 2006 | 03:44 PM
oak's Avatar
oak
why didn't they design it with a larger intake hole?
Old Feb 19, 2006 | 03:48 PM
PorschePhd's Avatar
The profile of the box around the venturi does not have enough room to allow the neck to simply slip out. If you tried to make is bigger to pull up you would go right through the top of it. The short of it, no room.
Old Feb 19, 2006 | 03:49 PM
oak's Avatar
oak
different filter design?
Old Feb 19, 2006 | 03:52 PM
PorschePhd's Avatar
One could do that but the design and pick up in HP comes from the venturi. You can't create a venturi the same size as the original inlet. It would then neck down smaller than the original pipe defeating the purpose.
Old Feb 19, 2006 | 10:18 PM
Zippy's Avatar
I got mine in without taking the box out. It wasn't pretty, but it went in.
Old Feb 20, 2006 | 02:38 AM
sharkster's Avatar
Mike you are so naughty!
Jun 10, 2017 07:45 PM
tropicatango
Dec 4, 2015 02:45 PM
ECS Tuning - VW
Aug 19, 2015 11:08 AM
