Going to be a global suspension refresh
Old Mar 11, 2019 | 10:27 PM
vogz's Avatar
vogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond repute
Originally Posted by Third-Reef
I did shocks, springs, front top hats, rear solid thrust bushing, Porsche RS motor mounts, window weld trans mount and GT3 rear cross member all at the same time. I aligned it myself. So far I have 1 track day and 26K commute miles on my PS2s. Still look decent, getting a little slippery in the rain though.
Gotcha. Thanks for the info.
Old Mar 12, 2019 | 08:13 AM
wab_jr's Avatar
5 Year Member
wab_jr has much to be proud ofwab_jr has much to be proud ofwab_jr has much to be proud ofwab_jr has much to be proud ofwab_jr has much to be proud ofwab_jr has much to be proud ofwab_jr has much to be proud ofwab_jr has much to be proud of
Suspension Hardware detail
[QUOTE=JSBear;4770860]Can you break down part numbers and where you sources, may be good for reference, I'm thinking about doing this.
I ordered all hardware parts & pieces from Annapolis Porsche. Good pricing & great service:
Part NumberPart NamePriceQuantityTotal
996-333-107-00Shock Mount Washer$26.322$52.64
999-084-445-01Ft Lateral Arm Lock Nut$1.5714$21.98
999-025-240-02Bumper Washer$4.632$9.26
900-378-322-01Hex-Head Screw 12X7$2.062$4.12
900-380-008-01Air Spring Nut$1.572$3.14
996-343-521-01Strut Washer$17.592$35.18
996-343-507-02Lower Seat$90.821$90.82
996-343-508-02Lower Seat$72.641$72.64
996-343-513-00Stopper Washer$1.782$3.56
996-343-107-03Ring Stop$36.922$73.84
996-343-525-00Plate$14.101$14.10
996-343-525-01Plate$12.241$12.24
996-343-523-00Support Ring$20.151$20.15PAF-003-923Hexagon Nut$0.626$3.72
900-380-012-01Top Nut$1.496$8.94
900-378-191-01Lower Seat Bolt$4.022$8.04
900-377-010-01Support Bracket Nut$0.362$0.72
900-378-165-01Track Bar Bolt$3.132$6.26
900-378-329-01Control Arm Bolt$3.412$6.83
900-378-145-09Screw M 14 X 45$4.182$8.36
900-378-135-01Lateral Arm Bolt$4.754$19.00
900-378-211-09Support Brace Bolt$1.684$6.72
997-331-217-02Rear Lateral Rod Adjust Bolt$10.342$20.68
996-331-219-00Lower Control Arm Adjust Cam$8.774$35.08
900-378-051-01Hex-Head Bolt 14X100$7.912$15.82
999-084-452-09Nut M12$2.934$11.72
900-378-139-01Stabilizer Link Bolt$6.284$25.12
900-378-088-01Impact Bar Mount Bolt$3.494$13.9
999-084-449-09Outer Tie Rod Nut$1.574$6.28
997-331-217-03Adjust Bolt$10.342$
Old Mar 16, 2019 | 08:44 AM
techweenie's Avatar
techweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant futuretechweenie has a brilliant future
I bought all the parts I thought I'd need and took it all to my suspension guru. He used everything except the lower control arms. So I have 4 lower control arms I don't need. I'd like to recover what I spent: $187.96 for all 4.
Ducgsxr
Apr 12, 2014 03:48 PM
