Need help with Coilovers
Old 02-22-2006, 11:50 AM
willcoxmd's Avatar
willcoxmd is infamous around these partswillcoxmd is infamous around these parts
Hey guys. I know this has been discussed, but I can't search to forum. I've just pulled the trigger on a Fabspeed exhaust and ECU Flash and want to upgrade the suspension. I'm very close to buying a used JIC Cross setup, but have heard a few negative things from a couple 6speeders.
I use this car as a daily driver, have never tracked it. I would like to track it sometime for kicks, but this will be a rare occasion. I just want it lowered and a little tighter. Recommendations?
PSS9's, JIC, ROW? what would do you guys like?
Thanks,
Todd
Old 02-22-2006, 11:55 AM
02barebones996's Avatar
02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute
choose between pss9's or jic id skip row all together the coilover system give u the adaptability that the row suspension cant give you..
both systems have their faults and plus's
Old 02-22-2006, 03:16 PM
YoWils's Avatar
YoWils is infamous around these parts
I've only had mine for a few days (JIC's 9kg/12kg), but it's been super compared to PSS9's so far. Ride quality is great, and handling is great. The front is even a tad lower now (115mm/120mm f/r).
Old 02-22-2006, 03:56 PM
wross996TT's Avatar
Are the JICs overkill for a road? Lots of $ for just DD IMO. Go PSS9.
Old 02-22-2006, 04:04 PM
Up On 3 Racing's Avatar
Up On 3 Racing is infamous around these parts
You want to find out what spring rate is in those coilovers. I don't remember the numbers off the top of my head, but they have a few different spring options. I know that recently they have been softening up there spring rate to accomodate the daily driver. However, if they were purchased a few years back they have the siffer springs and is probably the reason they were removed from the original car. If you find that they do have the stiffer springs you can order a softer set from JIC. As for performance you get a big bang for your buck. The nice thing about the Cross is that they include the monoball kit which will help when it comes to setting diffrent cambers and your alignment all together. Another plus is that they are 15 way adjustable verses most that are 9 way adjustable. In whatever suspension you get just make sure you pay close attention to your spring rate. Good luck, drive fast and don't get caught.
Old 02-22-2006, 09:49 PM
YoWils's Avatar
I found the PSS9 a bit too soft and wobbly. The JIC's are actually quite good for street use, at least in the spec I run. They are not much more than what PSS9's run normally. In terms of $$$, they are a long, long way from Moton's.
I have mine on the stiffest setting, and with the 507/670 (metric conversion) spring rates, it doesn't ride any harsher than my Acura sedan. I know a few guys locally who've had problems with their older JIC's, but so far I haven't experience any.
Old 02-22-2006, 09:57 PM
sharkster's Avatar
Problems have usually been with the drop links and the springs being too stiff for the shocks. So they suffer from pogoing.. Stick to the "medium" springs and I think you guys will be a-ok
The camber plates are a nice idea, only trouble is you're not going to have much luck trying to adjust them on the car since there's no room to do so
Old 02-23-2006, 10:10 AM
Whirls's Avatar
Whirls is infamous around these partsWhirls is infamous around these parts
I put the RUF coilovers on mine and its awesome. The comfort level on the street is great and I have noticed a huge improvement on the track. You may want to give the RUF Auto Center in Dallas a call before making your decision....
Old 02-23-2006, 11:47 AM
willcoxmd's Avatar
I found a slight used set of JIC's and ordered them last night! I'm adding them to the list of mod's i'm collecting. I'll let you know when its done. Hopefully in the next couple weeks
02-24-2016 01:10 PM
mrmaass
10-09-2015 01:32 PM
09-28-2015 02:19 PM
MONKY LONDON
09-28-2015 07:16 AM
Zero911
09-24-2015 06:33 PM
Quick Reply: Need help with Coilovers
