Revved to redline - BANG!, see photo - ever see this?
Old Mar 6, 2006 | 09:11 PM
bond's Avatar
bond is infamous around these parts
Wouldn't the filter prevent the vapor from getting to the MAF? - how do you clean?, thx.
Bond
Old Mar 6, 2006 | 10:00 PM
ebaker's Avatar
ebaker is infamous around these parts
Bond, which hose blew?
Old Mar 6, 2006 | 10:17 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
When it happened to me the filter did not prevent the vapor from getting to the maf. I spent days trying to figure out why my car was running like it had just dropped a cylinder everytime I punched it. All I knew was that the problem started when the hose blew.
1-Disconnect the boost hose that attached to the pressure pipe on the drivers side.
2-Unclip the harness to teh maf.
3-Using a allen wrench take out the two screws
4-Pull the maf
5-Using a electrical cleaner, spray the maf down, making sure to get the inside too.
6-Let the maf air dry ONLY!
7-Put the maf back in, making sure its facing the correct way.
Jags
Old Mar 6, 2006 | 11:01 PM
bond's Avatar
Wow - you may have just saved me some major hair pulling and frustration - it really did not occur to me. After I read your post, I went back to take a look at the inside of the filter housing and, indeed, it is wet. What filter were you running? - stock housing?
What cleaner did you use?, My MAF uses a TORX type screw with a pin in the center - a special tool, it appears. I wonder if it coated the intercoolers enough to form a heat insulating layer - what a nightmare this seemingly simple hose issue is becoming!
Bond
Old Mar 6, 2006 | 11:07 PM
bond's Avatar
Water pump outlet to passenger side metal pipe (under PS pump)
Bond
Old Mar 9, 2010 | 09:02 AM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
Originally Posted by jags911tt
That happened to me a few months ago. The 2001 have a hose which has been updated. Once you replace the hose and get a coolant flush, you may want to clean the maf.
Jags
Is it this one (no pic)?
Water hose at Water Pump: Part #: 996-106-250-74-M100
http://www.pelicanparts.com/cgi-bin/...30%35%29%20%20
Think i read on another thread (which i can't find); there being a 997 part that is an upgrade to the OEM 996 unit. thanks
Old Mar 9, 2010 | 09:34 AM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
If you don't use the pump, when you first refill the coolant, put the back of the car up on jackstands to help get the air bubbles to the back. I did mine a year or so back, raised the back and filled it, then drove around with the valve up, topping off when necessary. Worked fine.
Old Mar 9, 2010 | 10:29 AM
No Name's Avatar
No Name is infamous around these partsNo Name is infamous around these parts
Since this happened 4 years ago, I would hope he already has the problem fixed!
Old Mar 9, 2010 | 10:46 AM
adeeois's Avatar
adeeois is infamous around these parts
+1 on raising the rear of the car. Recently filled mine from empty. My mechanic raised the back till the front spoiler was nearly touching the ground. He filled in controlled steps with the heater and fan on high, using a hand held thermal reader to monitor hose temps. He kept the RPM's up while bliping the throttle. Long process.
Old Mar 9, 2010 | 07:02 PM
Mad Ness's Avatar
yes sorry for dragging up an old post.
I tried bleeding my car that way, jacked it all the way up in the rear, front tires on ramps, and front lip touching the floor. In the end there was still air inside, that valve was always open, past the level that allowed the clip to "clip" in. Have since sourced a kit to do this.
Can anyone help with the part number on the "trouble" hose? Thanks
Old Mar 10, 2010 | 12:07 AM
Mr. C4's Avatar
Mr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to behold
Looks more like one of the boost hoses to me.
Old Mar 10, 2010 | 01:11 AM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
Originally Posted by MARKSKI@911tuning
not Ok to mix.... yes u have to make sure the no air pockets are let..... u rev up the car to 5K about 10 minutes and hold it foe a few seconds each time... cool down the car and check the coolant a few times after driving.
5k for ten minutes?????? are you sure?
Old Mar 10, 2010 | 07:37 AM
jjbravo's Avatar
jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !
+1 Boost hose....?
Old Mar 10, 2010 | 07:40 AM
Mad Ness's Avatar
Originally Posted by jjbravo
+1 Boost hose....?
think they look similar accept on boost hose only has couplings on one side; the underside short IC/Turbo ones. got photo off the #1post on this thread.
Old Mar 10, 2010 | 08:55 AM
Mr swed's Avatar
Mr swed is infamous around these parts
I think the hose number is 996 106 501 74 or 996 106 502 74
