Revved to redline - BANG!, see photo - ever see this?
Old Mar 10, 2010 | 08:58 AM
  #31
Mr swed's Avatar
Mr swed is infamous around these parts
by the picture it looks like 996 106 501 74
Old Mar 10, 2010 | 09:14 AM
  #32
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
This hose tends to hit on the engine mount under heavy acceleration and overtime will fracture like this, I've had it happen on the drag strip, not a fun experience Use a pressure bleeder to pressurize the coolant system and allow you to add more coolant.
The part number should be on the hose itself, if you can snap a picture of which 1 of the 2 hoses it is in the engine bay I can get you the correct part number.
Old Mar 10, 2010 | 09:45 AM
  #33
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
mr. swed and one love, thanks for reply. Mine aren't busted, just want to do preventative maintenance while the engine's out. The photo is from the OP of this thread.
Are both problematic or just one side? Suppose I should just replace both for good measure but it's good info to keep mind of and inspect from time to time.Guessing more solid than OEM engine mounts may help.
thank you
Old Mar 10, 2010 | 10:10 AM
  #34
onelove's Avatar
I would go ahead and replace both. The one closest to the motor mount is usually the culprit, but the o-rings can also be a problem when these hoses are removed and reinstalled. I would replace both hoses and the o-rings on the couplers at the same time.
Old Mar 10, 2010 | 06:57 PM
  #35
Mad Ness's Avatar
awesome, much appreciated.
Old Mar 10, 2010 | 07:08 PM
  #36
Mr. C4's Avatar
Mr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to behold
Originally Posted by Mad Ness
think they look similar accept on boost hose only has couplings on one side; the underside short IC/Turbo ones. got photo off the #1post on this thread.
I/C to Y pipe has a flange both ends.
Old Mar 10, 2010 | 07:39 PM
  #37
Mad Ness's Avatar
Just checked pelican for the coolant hoses. The old part numbers given above have been superseded by 996-106-501-76-M100 & SS 99710650200
Ellipsis
Mar 28, 2016 03:28 PM
kahala997s
Sep 15, 2015 05:15 PM
Vrrooom
Sep 15, 2015 02:03 PM
