Ruf Pss9 suspension spring rate
Old Mar 14, 2006 | 05:54 PM
jro's Avatar
jro
jro is infamous around these parts
Question Ruf Pss9 suspension spring rate
I was wondering if anyone knows if you can change the spring rate on the Ruf Pss9 sports suspension kit? I'm looking for a more firm ride.
Old Mar 14, 2006 | 06:44 PM
Ruiner's Avatar
I know that JIC offers different rates (I had them change mine). I am not sure about the PSS9s...
Old Mar 14, 2006 | 09:47 PM
wross996TT's Avatar
I know there are different springs you can get for different PSS9 set-ups. I have the FVD version and it is stiffer than the US version. Not sure about compatibility across set-ups though.
Old Mar 14, 2006 | 11:56 PM
Turbo Fanatic's Avatar
I also have the FVD Pss9s. I believe it has stiffer main springs.
Old Mar 15, 2006 | 01:47 AM
Erik's Avatar
Erik has a spectacular aura aboutErik has a spectacular aura about
It should be adjustable, there's a "****" at the end of the thing.
See here: http://www.rs6.com/forum/showthread....&threadid=8583
Old Mar 15, 2006 | 09:06 AM
Ruiner's Avatar
That doesn't control the spring rate, however...
Old Mar 15, 2006 | 10:16 AM
jro's Avatar
jro
Thanks, I have played around with the shock settings, and it has firmed up the ride a bit. I think that is more of a spring damper control though. Overall, I am happy with the ride, but with these wonderful maintained Northern California roads, it feels like the spring rate is not responding quick enough, and it tends to get a little bouncey at times.
Old Mar 15, 2006 | 11:14 AM
Bruce's Avatar
Member
Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !
I believe the PSS9 spring rates are all the same (maybe different for Euro vs. US versions), Ruf changes the shock damping a bit but the spring rates are the same. Ruf also supplied a new rear sway bar with the kit which improved things quite a bit.
Old Mar 15, 2006 | 03:06 PM
sharkster's Avatar
I know what ya mean The spring rates in general for PSS9s are pretty low for the weight of the car... You're options get more expensive in terms of Motons or JIC's (although some people have had drop links go on the latter).
Old Mar 16, 2006 | 02:30 AM
SDboosted's Avatar
SDboosted is infamous around these parts
heya john, there's another german tuner that has a pss9 based system with appropriate spring rates for the rear weight bias of the TT.
motorsport valving too.
PM me for info...
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
MadWhip
Sep 3, 2015 02:04 PM
orbelo
Aug 30, 2015 12:26 PM
ECS Tuning - VW
Aug 26, 2015 12:33 PM
ECS Tuning - VW
Aug 25, 2015 11:53 AM
