What is needed (related to removing wheels)
msindi:
I hate wheel locks, haha. Always can never find them when you are trying to take the wheels of a customer's car.
Evan:
Another note to follow besides removing with a rachet and not the torque wrench (good tip btw) is to always torque the wheels using the 5 star pattern. Never go in a circle following one lug to the next. Always move across the hub to the lug directly across from the one you had just tightened. This helps to evenly tighten down the wheel and will not "warp" your rotors from tightening on side down before tightening down the other.
Evan:
Originally posted by Joe Weinstein
I do a lot of wheel swapping on my Mustang, and I have
a DeWalt 12 volt cordless impact wrench 1/2" driver, with
a deep 3/4" socket for loosening and removing lugs, and
for tightening to just over finger-tight. This saves a lot of time.
The impact wrench can only make about 100 ft-lbs max
torque, so it's just enough to remove lugs, and I don't let it
run enough to tighten them much. Then I use the torque
wrench for exactly what it's made for, just tightening to the click.
DeWalt's better, but all the prices I've seen were quite a bit higher. But either way, the cordless impacts are very nice, if you do a lot of wheel swapping.
Originally posted by msindi
HRE makes lugs?? My wheels came with no lugs and I used stock!!! No wonder they are so freakin tight!!
.Thanks Peter, I have ballseat (chrome) lugs, so they should be the same as stock...
Evan
the wheels can be cut for either ball (stock lugs) or conical seat (HRE lugs) - we always ask the customer first, but most people go for the conical seat and HRE 17mm lugs after we tell them about it
Originally posted by lee2375
thats why we recommend all of our customers use HRE's lugs...the 17mm head is a lot easier to remove than a 19mm...
. If I could do it over I would prob do Conical...maybe I will do it over again
....still working on it Peter, I will email you later
Evan
Really?? I was gonna get bling bolts and locks too but factory size from Ralph Booth...
I am confused now, should I do HRE bolts or stock on my 841s?? Is there an extra charge for hardware form HRE?? If so how much (16 bolts and 4 wheel locks in chrome!!)
Evan got any closeup pics of yo hardware?
Evan
Sep 1, 2015 03:16 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
