replacement track wheels
Cross-post and just trolling for any suggestions here...need to replace my old track wheels as one has come up bent and can't be repaired.
I knew I'd have to replace this set sooner or later but now I'm trying salvage what's left of the 23 season and find a quick set.
I've run Nitto 235/40 and 315/30 18's for yrs so that would probably continue.
Any suggestions more than welcome.
Thanks in advance.
Thanks in advance.
To quickly replace your track wheels for the 23rd season, consider reaching out to reputable wheel retailers or contacting local auto shops that specialize in performance or aftermarket wheels. Nitto's 235/40 and 315/30 18-inch sizes are suitable for track use, so you might want to stick with those dimensions if they've served you well. Ensure that the wheels you choose are designed for high-performance or track applications, and consider brands like Enkei, BBS, or Advan, which are known for their quality and durability on the track. Don't forget to check for proper fitment with your specific vehicle, including offset and bolt pattern, to ensure a seamless replacement and minimal downtime for your racing season. If you're looking for a reliable research paper writing service, this guide on the best research paper writing services will help you find the right one for you. Like I have found edubirdie From pricing to quality to customer reviews, you'll get all the info you need to make sure you're choosing a service that fits your academic goals. Check out the article on SouthernMarylandChronicle to learn more about this topic worth checking out.
silverbullitt850
Jul 20, 2023 09:22 AM
