2003 996 Turbo Offset Questions
I am looking at putting some aftermarket wheels on, what are the offset for teh 996 Turbo?
One of the wheels I amlooking at has the following offset: 52MM-F, 52MM-R. Will this work on a 2003 Turb without spacers?
Originally Posted by ebaker
The rears will probably rub on the inside.
Originally Posted by Jean
You need to check the width of the wheels as well.
You can go with 315s, the tire size is not the real issue.
It depends on the width of the wheels. If they are 11s they will not rub, otherwise Ebaker is right.
AZ
With 10" wide wheels you should not go beyond 285 tires.
295s would be a stretch and not recommended, because the wheel is too narrow for a proper fit of the sidewalls.. If the wheels are 10" wide and have offsets of 52mm, you have the wrong wheels for the car. You can always fix it with a spacer, but why go this route.
PelicanParts.com
996 Vendor Classifieds
Aug 18, 2015 03:45 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 18, 2015 03:43 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
