100 Octane & Boost ??
Old May 4, 2006 | 09:04 PM
AzExoticLover's Avatar
AzExoticLover is infamous around these partsAzExoticLover is infamous around these parts
Guys - would I see a difference in the amount of boost (Bars) with running 100 octane and having the flashloader set with the 100 ocatne map -vs- just using crappy AZ 91 octane?
For example: If I am running 1.1 bar (with an occasonal 1.2 bar) now with 91 octane on a stage IV could I assume that with the same Stage IV set up would run 1.2 or even 1.3 bar with 100 octane and the 100 program?
Old May 4, 2006 | 09:35 PM
RennTechV12's Avatar
RennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond reputeRennTechV12 has a reputation beyond repute
When you run lower octane fuel than your ECU is programmed for, the ECU automatically pulls timing to prevent detonation and engine damage. You may not boost more PSI, but your ECU won't be pulling timing, so you will make 100% of the HP that you should be.
Old May 5, 2006 | 03:53 AM
Get the WGs cranked up... or if that doesnt work.. and may not in ur case... upgrade tot he stiffer springs... and make sure ur tuner does it so they dial in the boost correctly... I also ran my FVD stage 4 with k24 race turbos and it only stayed at 1.1 or peaked 1.2 and then dropped off to 1.1...
and to make things worse.... I wouldnt hit 1.2 bars or so till top of the 3rd gear. i hooked up a boost controller and it help a bit... the problem is the soft WG springs... and yet they cant be too strong either.
If I only knew what I know now.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
proTUNING Freaks
Sep 15, 2015 07:28 AM
JSF721
Detailing
Sep 8, 2015 07:57 AM
916er
Sep 7, 2015 09:50 AM
captain Greg
Sep 6, 2015 04:14 AM
yumaverick
Sep 2, 2015 03:48 PM
