Anyone here use a Front Strut Bar?
Old May 18, 2006 | 06:52 PM
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
Was wondering if any of you guys have a front strut bar on your cars. Is it even worth it to get one, I mean will it help out the suspension especially in a track environment? If they are worth getting, which brand is the best one?
Old May 18, 2006 | 06:59 PM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
I have heard they really do not do much for the Turbos, but I am not a pro. I had a Dinan strut bar on my M3 Cab, and it helped with cowl shake.
Old May 18, 2006 | 08:22 PM
tom kerr's Avatar
I thought the reason you dont see much about this is the 996 already kinda has it built in?
Old May 18, 2006 | 08:44 PM
sharkster's Avatar
that's correct Tom.. I was skeptical of them but then again when the Peterson White Lightning Race team tore there car apart for a Laguna Seca race at our shop.. sure enough they had one of those up front. Pretty sure it was the EVO one from what I remember.
Old May 18, 2006 | 11:38 PM
glpdx's Avatar
glpdx is infamous around these parts
Now I'm confused. I think Tom is saying the CF Strut Mounts like the ones offered by EVO are kinda redundant to something the factory has already built in. I've been hearing they are mostly a psychologial improvement.
I like this thread. I would love to hear the various opinions.
Old May 18, 2006 | 11:46 PM
Wait, do we have OEM front strut bars in our cars??? I'm really confused now...
Old May 19, 2006 | 01:07 AM
YoWils's Avatar
YoWils is infamous around these parts
I've found the Evo front strut bar really help make the steering feel a lot more tidy. It was otherwise kinda sloppy.
Old May 19, 2006 | 09:03 AM
wross996TT's Avatar
Well I'll add to the confusion...In my older P-cars the strut bars were essential and helped with handling. In my "newer" 996 I was also under the impression that the frame/body was improved structurally to the point where a strut bar was not really needed...even on a cab. Maybe the strut bar is needed for track?, but for everyday driving??? Also what about sway bars?
Old May 19, 2006 | 09:55 AM
KPV's Avatar
KPV
The top of the strut towers on older 911's were essentially unbraced across the width of the car. Under hard cornering, the strut towers had the potential of flexing inward or outward as a result of the cornering forces. This would lead to handling irregularities as the camber would change in the middle of the turn due to tower flex. There were (are) a variety of strut bars designed to combat that problem. The best of which in my opinion is the "Cambermeister". It isn't pretty, but it really was designed properly.
The 996 series of 911's have a sheet metal bulkhead (both horizontal and vertical sheet steel) that interconnects the two towers. You can see this on the car if you open the hood and remove the battery cover. It is the bulkhead with the rubber weatherstripping on it as well as the battery floor. These two sheet metal body components form an "L" shape in cross section and are infinitely more rigid in compression and tension (the way a strut brace works) than any strut brace can ever be.
The rear strut towers are similarly designed.
Old May 19, 2006 | 10:07 AM
WOODTSTER's Avatar
I agree with KPV again,
996 has strength built into its design,
they do look cool though and I like cool.
MK
Old May 20, 2006 | 01:35 PM
Grimm333's Avatar
Grimm333 is infamous around these parts
hey trojan man
so this is where you disappeared to
Old May 20, 2006 | 02:48 PM
paneraiwatches's Avatar
paneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to beholdpaneraiwatches is a splendid one to behold
Have a Techart brace up front. No noticible difference in handling, but it does look cool! LOL
Old May 20, 2006 | 03:26 PM
cjv's Avatar
cjv
Moderator
KPV,
The 996tt are built stiffer, however there is plenty of room for improvement in the stiffness department, especially in regards to track work. Then again, where do you want the street to stop and the track begin. Recently Ben removed teflon tranny stiffners from his car because of the noise. As you continue up the peformance ladder there is a price to pay. There is no doubt that the 996tt is stiffer than the 993tt, just as there is no doubt the stiffiber does help in track situations.
Old May 20, 2006 | 04:54 PM
Q8_TwinTurbo's Avatar
Q8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud of
USATrojanMan29,
For track use i would recommend you go with a front strut bar. I have fixed one on each of my Porsches. A 1994 965 Turbo 3.6, as well as my 2001 996TT. It made a huge difference on the 1994 965 Turbo 3.6. On the 2001 996TT, you might not feel the difference too much, but it's there for sure. Fixing a Porsche Tequipment roll bar and a set of Billet Camber Plates / Strut Mounts would help things tremendously. Evolution Motorsports has them all. There are two types of strut bars, Carbon fiber or Billet. below is a link you can check out.
http://www.evoms.com/porsche%20ec%20art%20test.htm
Old May 20, 2006 | 05:25 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
Originally Posted by Grimm333
hey trojan man
Why you sellin your car?
