What Boost Pressure for Stage 4?????
As you guys may know, I suspect my car is not producing the boost pressure (and hence horsepower) that it is supposed to. This is based upon the results of the recent dyno test at AWE Tuning. I believe the culprit is an incorrectly adjusted passenger side wastegate actuator rod. I had to replace it when the original one was bent upon receipt.
I am trying to get to the bottom of this and wanted to start my research by querying those with Stage 4 kits.
What boost pressure are you seeing under full-on acceleration???
I have only seen 1.1 bar so far. Should I be seeing 1.2 bar?
I think you're fine...
I have the EVO stage IV setup and in regular (non race) mode, I only see 1.1 bar for boost with 95 octane fuel.
However... If I go chipswitch to stage IV Race program, then I see 1.3 bar.
I wouldn't worry about it... if there is a problem; we both have it.
<grin>
Joe West
<grin>
Joe West
Re: What Boost Pressure for Stage 4?????
I have stage 4 from IA and I see spikes to 1.2 on a regular basis...
Ken,
Your WHP to FWHP conversion on the mustang dyno brings you above the advertised 600FWHP.
According to Buddy who spoke directly to the guys at Mustang, conversion from WHP to FWHP uses a loss factor of 23-25%.
Using the lowest conversion factor (23%), you're making 602FWHP.
Should be 1.2 on average. The gauge can not be trusted as I have said before. Also if your wastegates have not been set they are to conservative and should be adjusted.
Kevin,
Hmmmmm. Interesting comment. My understanding is as follows. Please feel free to correct me if I mistate anything because I really need to understand this.
Wouldn't the throttle body be forced to shut down if the wastegate was not large enough to bleed the excess boost pressure?
- If my wastegate actuator is incorrectly adjusted, I should be prematurely bleeding off boost pressure. This will result in less than optimal performance on the dyno.
- If I "tighten" it up a bit (5mm per Stephen's suggestion) then the previously bled boost will be redirected to the intake. By tightening, I am referring to adjusting the actuator rod such that the stroke of the wastegate is limited. This limitation in stroke directly limits the size of the wastegate opening and thus the amount of bled boost.
proTUNING Freaks
Sep 15, 2015 07:28 AM
