PSS9 dial adjustment
Old May 21, 2006 | 07:25 PM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
Well, went to adjust my PSS9's to 3/2 and now have confused myself which way is correct. I can barely feel any clicks on the front and get confused since it is upside down. Can someone please refresh my memory on how to adjust the PSS9's, since my brain is going blank on left to right turns for the front and back. Guess my question is if I am in the back looking down, which way way do I turn to start at 1 and adjust to 3(there is a - then a + then 1 but no markings to show where 1 should be.) Thanks.
Old May 21, 2006 | 07:43 PM
BigBadBen's Avatar
BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !
9 is softest setting, 1 is hardest. I have the same setup, you should be able to see the numbers but they are spaced out oddly...you can feel the click for each setting but its very subtle...take a flash light and you will see the numbers...hope that sort of helps.
Old May 21, 2006 | 09:10 PM
kc911's Avatar
kc911 is infamous around these parts
You are supposed to go counter-clockwise to go firmer ie. going 3 to 2 to 1 and clockwise to soften ie. 3 to 4 to 5. My left side rear clicks just fine but my rightside does not seem to click at all.
Good luck,
k
