EVO waste gate springs
Originally Posted by MARKSKI
the boost comes on faster... and it holds boost better....
the trick is to have a program tuned for external WG control... just like in all other turbo cars.... via a boost controller.. thats just my opinion..
electric one
2001 996TT 3.6L and stock ECU
Originally Posted by iLLM3
Ahh figured that would be the only way to fine tune a setup and be able to switch off, how difficult is this, just wondering!
Wastegate springs: I assume "calibrated" means tighten the bolt (clamp the stock spring tighter). Calibration helps, but does not performs nearly as well as upgraded springs IMO.
For boost controller: Basically you need to intercept the boost signal going to each wastegate and splice in your boost controller. Have been doing this on various cars (not the Pcar) since 1989... Damn I'm old.
Originally Posted by ari
Wastegate springs: I assume "calibrated" means tighten the bolt (clamp the stock spring tighter). Calibration helps, but does not performs nearly as well as upgraded springs IMO..
ModBargains
Sep 12, 2015 12:55 PM
