Stupid Question - Longer wheel bolts
Old Jun 17, 2006 | 05:23 AM
Turbo Fanatic's Avatar
When bolting on wheel spacers, does the TT use a stud and nut system or just a longer wheel bolt.
I guess I could answer by pulling out the lug wrench, but this a lot easier.
Hey ILL: when are your wheels coming? I'm getting antsy!
Old Jun 17, 2006 | 01:30 PM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
First...an OE Turbo has no spacers.
But otherwise.........for aftermarket most people just use longer bolts (for a relatively small space).
And beyond that, and most would say if you are past a point in thickness you should always use bolt-on and nut arrangement and site safety is the reason.
The 3rd group of people will say.......don't use spacers....buy the right offset
Old Jun 17, 2006 | 04:59 PM
I'm using 15mm spacers with stock wheels. No choice on the offset...
Jun 10, 2017 07:45 PM
no1joey
Sep 2, 2015 12:32 AM
Aug 21, 2015 09:56 AM
cab83_750
Aug 19, 2015 12:37 PM
