PSS9 Question
Old 01-04-2004 | 09:43 AM
Orli930's Avatar
Orli930 is infamous around these parts
PSS9 Question
I am considering changing out my stock suspension for the PSS9's . I was told that even if I set the PSS9's at its lowest setting (Lowest meaning best ride) it will still out handle my car in its stock trim. Is that true?
I just don't want it to ride very hard or low (keep in mind I have the factory 18" wheels) . But I want the flexiability to change the setting if I want to play at the track.
Suggestions, comments or advise would be appreciated.
Old 01-04-2004 | 10:33 AM
sporters78's Avatar
sporters78 is infamous around these parts
orli930,
i have the ruf pss9 on my car, ride is a lot better then stock, smooth ride when set at higher numbers with no front end lift like the stockers, set it at low number and it just hugs the road. if you get up north a little you can take a look at mine.
Old 01-04-2004 | 10:36 AM
Zippy's Avatar
Do you ahve to jack up the car to make adjustments?
Old 01-04-2004 | 11:50 AM
sporters78's Avatar
on the front its easyer to jack it up to get to the *****. on the back 5 min job inside the car
Old 01-04-2004 | 12:08 PM
Orli930's Avatar
Sporters,
Let me know I would like to see your car. I will drive north to Boca. No problem.
Old 01-04-2004 | 02:46 PM
Turbo Ron's Avatar
Turbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to all
I have mine set at 4 front and back. Less harsh than the stock suspension. Dropped the car in front 3/4 of an inch. 1 degree nose down.
Old 01-04-2004 | 04:41 PM
ESK's Avatar
ESK
Hick from NH
ESK is infamous around these parts
Orli,
You swore you would not lower your car! There goes that beautiful aerokit front spoiler!
Eric
Old 01-04-2004 | 04:49 PM
Chris Y.'s Avatar
Chris Y. is infamous around these parts
I also have the RUF PSS-9s...I concur with the other PSS-9s..that even at settings of 3 & 4, the ride is much more complaint compared to the stock. I just got a chance to drive an '04 TT cab and I was suprised how rough it rode for a stock car. I went as far to checking the tire pressure and it was actually on the low side of 34/37 from the rec. 36/44.
I say go for it and at least lower it an inch to RoW height...
Old 01-04-2004 | 06:43 PM
Suneal's Avatar
Suneal is infamous around these parts
Just curious, I know that you have to re-align your car whenever you change your suspension out (and height when you have coilovers)- do you have to re-align your car when you change the stiffness of your shocks and/or spring rates?
Old 01-04-2004 | 06:45 PM
Orli930's Avatar
Eric,
I know but I drove a TT with the PSS9 yesterday and it handled great.
What is the least amount the car would be lowered? If I am going to have this problem with the Aerokit........Forget it.
Old 01-04-2004 | 07:58 PM
Turbo Ron's Avatar
If you just change the firmness settings, you do not have to realign the car.
Old 01-04-2004 | 08:53 PM
Chris Y.'s Avatar
If I'm not mistaken and when I was playing around with my heights, you can actually match the stock heights...Sound correct, those with PSS9s?
Originally posted by Orli930
Eric,
HotRod
09-10-2015 07:17 PM
MadWhip
09-03-2015 02:04 PM
orbelo
08-30-2015 12:26 PM
LiquidElephant
08-27-2015 06:17 PM
TrackOne
08-20-2015 12:56 PM
Quick Reply: PSS9 Question
