Bizarre squeaking noise eminating from the dashboard?
Old Jul 14, 2006 | 02:29 AM
T.Rex's Avatar
T.Rex is infamous around these parts
Bizarre squeaking noise emanating from the dashboard?
Lately there's been an intermittent "squeaky squeaky squeaky squeaky squeaky squeaky" noise coming from behind my dash. At first I thought it was A/C, but it's still there even when the A/C is off. The sound goes away when I press the clutch pedal.
My warranty expires in 1 month, anyone have any ideas what could be causing this?
Thanks.
Old Jul 14, 2006 | 04:12 AM
ScottKelly911's Avatar
ScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond repute
Usually this happens 1 month AFTER the warranty expires, not before...Hmmm...it could be mice j/k, good luck on figuring it out. I'd bring it in and get it taken care of before the Warranty runs out, if you get this started before hand, then they'll most likely take care of it even if the problem extends past the warranty if the problem is addressed prior to it running out. So take it in.
Old Jul 14, 2006 | 09:08 AM
chucksweet's Avatar
chucksweet is a glorious beacon of lightchucksweet is a glorious beacon of lightchucksweet is a glorious beacon of lightchucksweet is a glorious beacon of lightchucksweet is a glorious beacon of light
Thanks.
What year is your car? I had a problem that sounded similar and it ended up being the windshield was moving in its frame. I believe there was a service bulletin on it and some newer designed parts. My car is a 2001 and it was covered under warranty.
Chuck
calexand
Nov 5, 2015 01:05 PM
rob4wellness
Oct 2, 2015 07:32 AM
Compukidd
Sep 30, 2015 11:03 AM
larryg
Sep 28, 2015 11:16 PM
