Whats missing in this picture?
Old Jul 18, 2006 | 01:06 PM
adybuncio's Avatar
That looks insane, but would defintely get cooler air
Old Jul 18, 2006 | 01:32 PM
iLLM3's Avatar
Dammmmm 9400
Old Jul 18, 2006 | 02:48 PM
TKDalumni's Avatar
TKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really nice
That setup looks crazy!!
Old Jul 18, 2006 | 02:55 PM
HotRodGuy's Avatar
Originally Posted by buddyg
Craig,
I totally agree that 9ff setup would have your filter filthy in 5 minutes of driving on the street??
I think it'd be fine, I've run filters in similiar positions down low but up in the front, totally exposed to the elements and never had a problem. This is no different then many cold air intakes on cars. Of course, don't go flooring it through any streams
Old Jul 18, 2006 | 02:57 PM
Originally Posted by ECB
that filter has over 2000 miles on it! not that dirty at all. also...a filter in the path of the IC ducting is not really ram air...now I definitely would avoid fording any streams!!!just thought some of you would like seeing something different. I was pretty excited. mark what did you do with your MAF?
we do a similar set up on the evo8 I have... 700 hp daily driver... the filter goes right on the cold side...
My car has a custom MAF with a bigger MAF housing...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 18, 2006 | 06:07 PM
orijinal_poser's Avatar
orijinal_poser is infamous around these parts
custom blow off valves??
those look like your standard greddy type-s's to me.
Old Jul 18, 2006 | 07:23 PM
L Gancho's Avatar
L Gancho is infamous around these parts
I don't understand why anyone would want to replace the diverter valves with blow off valves. Isn't the purpose of the diverter valve to recirculate the boost system with the unused charge? Why would anyone want to release the pressure in the atmosphere rather than recirculating it back into the system and really help eliminate turbo lag? IMHO, it would be better to keep the system pressurized and reduce the amount of "work" on the turbo's to recharge the system. Less work on the turbo's = less lag.
Old Jul 18, 2006 | 10:11 PM
Zippy's Avatar
Conceptually, I think it's a pretty cool idea. I would imagine spool time would be crazy quick. A lot of you guys know how the V-Flow increases throttle response and spool-up. Imagine how this set-up would perform. Great job of being creative and thinking outside the box!
Old Jul 18, 2006 | 10:15 PM
ITBs have been done on 993tts for a long time if Im not mistaken...
9.66
click to view
Old Jul 18, 2006 | 10:27 PM
Zippy's Avatar
"Forced Induction Performance Tuning", by A. Graham Bell
1. Blow off valves s/b between the compressor and the intercooler - not after the intercoolers. This significantly increases the efficiency of the intercoolers, by allowing the intercoolers to only cool the charge that will be used by the engine.
2. Recirculating hot/compressed air into the compressor reduces efficiency and raises inlet temps.
Old Jul 18, 2006 | 10:37 PM
Chasen1211's Avatar
Chasen1211 is a jewel in the roughChasen1211 is a jewel in the roughChasen1211 is a jewel in the rough
wow you guys at 9ff keep coming out with crazy cool stuff...totally wild!!
Old Jul 18, 2006 | 10:38 PM
ttgangsta's Avatar
ttgangsta has a spectacular aura aboutttgangsta has a spectacular aura aboutttgangsta has a spectacular aura about
WARNING STUPID QUESTION:
I am not a mechanic and I know it but I have a question none the less.
Would there be more heat around the 9FF intake due to its proximety to the engine, the turbos, and the brakes? I know whenever I have worked on my car the second you get close to the back of the car its steaming hot back there. Maybe there is so much air flow it doesnt matter, but I feel like the "protomotive" setup might have colder air.
Idk just a thought/question
Old Jul 19, 2006 | 02:19 AM
ECB's Avatar
ECB
ECB is infamous around these parts
Once the car is moving anything faster than a few miles an hour, the intakes have access to the greatest source of cold air...air completely outside the car (next to rapidly rotating wheels)
The other setup gets some cool air for sure...but there is more resistance introduced by the significant distance to the cold inlet via a relatively small caliber tubing. An additional point to consider is how much heat the piping retains. Remember resistance increases linearly as the lengthof the tube increases, but exponentially as the radius increases...In other words - the lowest resistance fluid circuit is one with the shortest, thickest tube.
The protomotive "setup" also creates a new flow variable by introducing curves (more resistance) and the resultant dependence on laminar flow to increase efficiency.
while the protomotive setup *may* be superior to stock - the turbos are STILL seeing a significant intake restriction compared to the filters fitted directly on the cold side.
Oftentimes, the best solution to a given problem is the simplest.
This kit is certainly not for everyone. Its for the driver who wants his power in a different manner. Sure there are technical advantages to BOVs, but this setup was created for customers who demand something extra and unique - but still demand a completely engineered solution replete with advanced programming (and that PSSSSSHT sound).
The power change is certainly different - different, immediate and powerful. You don't need to be brain surgeon to understand the advantages of a setup like this, especially when combined with custom 9ff turbos. Plentiful cold air, lowest restriction to flow...and BOVs!!
The "cost-conscious" members can take heart in knowing that the kit is a no-cost option on the 780, 840 and 910HP sport motors.
Old Jul 19, 2006 | 03:17 AM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
Once the car is moving anything faster than a few miles an hour, the intakes have access to the greatest source of cold air..air completely outside the car (next to rapidly rotating wheels).
The cost-conscious members can take heart in knowing that the kit is a no-cost option on the 780, 840 and 910HP sport motors.
Yes, but what is the cost of the 780, 840, and 910hp kits?
Old Jul 19, 2006 | 03:49 AM
ScottKelly911's Avatar
ScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond repute
I'd love to hear this system in use, maybe on a dyno. I wanna hear the Pshhhht sound lol
