need instructions: bleeding rear spolier hydraulics
Old Sep 22, 2010 | 02:03 PM
dzuperku's Avatar
dzuperku is infamous around these parts
Thanks Larry,
How often to you re-apply WD40?
Old Sep 22, 2010 | 07:17 PM
Mike01996TT's Avatar
Mike01996TT is infamous around these parts
Originally Posted by dzuperku
Thanks Mike! Now I just need to get to my auto store to buy some Lucas power steering stop leak and plan for a working saturday!
Did you happen to use any directions/ pics to do a step-by-step tear down?
I have a word document that is a collection of stuff from various sources I can send you but I don't have enough post to PM you. If you want it just PM me an email address and I will shoot it to you.
The rear deck can be removed by 4 bolts. Just mark the hinges before you remove it so you can put it back on without have to align it. I put it upside down on a padded blanket on top of a black and decker workmate and was able to slide the wing up close enough to connect the power connector.
Old Sep 22, 2010 | 10:08 PM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Originally Posted by landjet
Easiest way to keep this system working and reducing stress on the rams is to lubricate the the struts with WD40. This is a preventive measure, not a fix when the hydraulics go bad.
I am going to start doing it,thanks landjet
Old Sep 23, 2010 | 07:52 AM
landjet's Avatar
Thanks Larry,
I give them a squirt every couple of months. When I installed my new rear wing, one side stopped going down and I thought I would have to rebuild the system. A friend suggested WD-40 on the struts before trying a rebuild and it worked. Never had a problem since.
Old Sep 23, 2010 | 08:23 AM
wross996TT's Avatar
Old Sep 24, 2010 | 09:30 AM
dzuperku's Avatar
Red face
Thanks Mike,
I dont have enough posts either to PM When I get enough, I will
Old May 25, 2011 | 12:59 PM
Beachmaniac's Avatar
Beachmaniac is infamous around these parts
Thumbs up Forget the Hydraulics
I tried Mike's technique and is actually pretty easy process. However, I discovered my problem was the hydraulic pump. I also read in one of the hundreds of threads about a kit to fixed the wing all the way up all time and discard the hydraulic system.
I have plans to move to a GT2 wing and didn't want to spend thousands of dollars on a system that probably is going to fail again. So I did a little research in Ebay and found the site that sells the kit. Compare to the original systems this kit is very inexpensive and very easy to install.
It took me less than 2 hours to install and looks great. I'm not trying to promote any seller but this is a cheap fix to a costly repair. You can find the site in ebay under "996 TT Fixed Spoiler Rear Wing Kit". You can see the results in my avatar.
Old Sep 9, 2011 | 12:01 PM
Romans 1:16's Avatar
Romans 1:16 is just really niceRomans 1:16 is just really niceRomans 1:16 is just really niceRomans 1:16 is just really nice
It doens't look like the ebay guy is carrying the kit anymore.
Doeas anyone else know who sells a kit to keep the wing in the up position?
Old Sep 9, 2011 | 05:20 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Old Sep 9, 2011 | 07:48 PM
Jul 29, 2019 11:13 AM
PelicanParts.com
Aug 26, 2015 04:49 PM
PelicanParts.com
Cayenne 958 Vendor Classifieds
PelicanParts.com
Aug 26, 2015 04:46 PM
PelicanParts.com
Panamera Vendor Classifieds
Aug 26, 2015 04:45 PM
