Inside cabin A/C filter? Where? Mildew !!
Old Aug 12, 2006 | 07:55 AM
Divi996tt's Avatar
Divi996tt is infamous around these parts
I order mine through pelicanparts . Not sure if I can post a link to the site. Google it and look for Pollen cabin filters.
Old Aug 12, 2006 | 10:28 AM
Michael 996TT's Avatar
Michael 996TT is infamous around these parts
I have the same problem - thanks for the threads. Now I can get rid of the pine tree on the rear view mirror !!!
Old Aug 12, 2006 | 11:07 AM
Alpha's Avatar
Alpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud of
Old Apr 15, 2010 | 11:53 AM
Kevganzon's Avatar
Kevganzon is infamous around these parts
where can i get a cabin filter for a '02 996TT for a reasonable price?
Old Apr 15, 2010 | 09:44 PM
sav911's Avatar
sav911 is infamous around these parts
Originally Posted by Cody_1
On my 2002 the filter is located under the bonnet.
Pop the hood, remove the plastic cover over the battery (center, back).
Remove the plastic cover right next to that on the passenger side.
You should see the filter there.
It is really easy to remove - just lift up and pull toward you. Shouldn't take > 3 minutes for everything.
Hope this helps......Rich
Rich,
Sorry to threadjack, but is there supposed to be a third cover over the filter itself, once the passenger side perforated plastic panel is removed?
I ask because for some reason, the previous owner has put a piece of clear plastic sheet and painters tape draped over the cabin filter ... I'd assumed because a cover was missing, but your description sounds like the fiter element should be open to the air once the panel to the left of the battery cover is removed.
-chris
Old Apr 22, 2010 | 03:28 PM
XLR82XS's Avatar
Suncoast or Pelican parts.
gadgetman
Sep 10, 2015 03:29 PM
sparks
Sep 8, 2015 03:03 PM
Weebs
Sep 7, 2015 11:42 AM
DLF
Cayenne Turbo
Sep 3, 2015 01:36 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
