GT2 Cage
Old Aug 8, 2006 | 07:18 PM
SMR's Avatar
SMR
SMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the rough
Maybe, but strange that Porsche did include it from the factory then....
Old Aug 8, 2006 | 08:05 PM
20C4S's Avatar
the clubsport cage is the best. i have some pics of the install we did. let me try to find them.
Old Aug 8, 2006 | 08:21 PM
20C4S's Avatar
it's the same clubsport package that comes in ROW GT3. u have the option to go for rear section only, or add the front section, which bolts right on to the rear section. minor welding required. getting in & out of the car is not a problem. actually it's easier to get in & out since u have one bar to grab on. here are some pics.
Old Aug 8, 2006 | 08:23 PM
LUISGT3's Avatar
Arling,
How/where do the front bars go?
Old Aug 8, 2006 | 08:31 PM
20C4S's Avatar
unlike the rollbar, this cage bolts directly to the upper rear suspenion as well as the 4 points weld in both center & front of the car. it helps stiffen the chassis quite a bit. ZLP is right. the head protection will be an issue when using the car on street with no helmet. there're still plenty of room though.
Old Aug 8, 2006 | 08:37 PM
20C4S's Avatar
Originally Posted by LUIS95993
Arling,
hope the above pics answered ur question.
Old Aug 8, 2006 | 09:07 PM
LUISGT3's Avatar
They did
Thanks.
Old Aug 9, 2006 | 05:15 AM
SMR's Avatar
SMR
Thanks for the pictures
But this ic not the regular Cs cage here in Europe,can it be the Gt3 Cs RS cage the one that comes in white that you have powercoated black..?
Old Aug 9, 2006 | 09:54 AM
grussell's Avatar
grussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud of
Yes, Lucent painted the cage black. It comes white. The CS roll cage is the way to go and I am doing it soon. The tech bar is just a bling harness bar.
Old Aug 9, 2006 | 02:52 PM
Hamann7's Avatar
Porsche Fiend
Hamann7 is infamous around these partsHamann7 is infamous around these parts
Garrett, are you doing the Clubsport cage or the RS cage (with the extra cross-member)?
Old Aug 9, 2006 | 02:53 PM
Hamann7's Avatar
Porsche Fiend
If you're under 6' tall, I don't think head clearance should be too much of an issue, since the front section fits pretty tightly to the A/B pillars. As the pix show, the side window is not obstructed at all by the front bars
Old Aug 9, 2006 | 04:00 PM
SMR's Avatar
SMR
So nice to here that from you also, same as i think..
Old Aug 9, 2006 | 04:02 PM
SMR's Avatar
SMR
Im exaktly 6 fot...
Old Aug 10, 2006 | 12:09 AM
mooty's Avatar
mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !
the cs cage DOES require cutting. you need to cut the rear parcel shelf to bolt the rear legs to shock tower.
the legs behind front seats are bolted to a metal pcs WELDED to the tub, whick also mean you are cutting through carpet, in addition to welding.
sure porsche sells GT3RS with the cage, but only the rear section is mounted. the front is intended to be used on the track. can you drive it on street, sure. if you are hit, you will more likely crack your head than if you dont have a roll bar.
regardless of which bar you want, das, cs, cup car, tequipment, take a browse through tcdesignfab.com. he has duplicated the rs rear section in my car and fong's car (white cage).
cs cage needs to be either painted or powder coated.
Old Aug 11, 2006 | 05:17 PM
grussell's Avatar
I think the CS Bar (rear only)
irish100p
Oct 24, 2015 09:37 AM
BLKMGK
Sep 19, 2015 03:51 PM
HIX
Sep 9, 2015 04:45 PM
