Just Installed K24's
Old Aug 23, 2006 | 08:50 PM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
What Bar Should I Be Seeing In 4th Gear With K24's & Giac Stg 3/4 Tuning?
Old Aug 23, 2006 | 08:54 PM
Ps I Also Have The Upgraded Wastegates From Evom.
Old Aug 23, 2006 | 09:04 PM
vipertestarossa's Avatar
vipertestarossa is a jewel in the roughvipertestarossa is a jewel in the roughvipertestarossa is a jewel in the rough
should be seeing 1.2 BAR
Old Aug 23, 2006 | 09:40 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
dam you car top out in 4th ??? wish i had the room by the time i reach 4th it's time to shut down way to fast in the neighborhood..............
Old Aug 23, 2006 | 09:41 PM
paulie how about a pic thanx steve
Old Aug 23, 2006 | 09:49 PM
Stevie, As Soon As I Get Off My Lasy *** & Figure Out How Too Post Pictures I Will. To Get An Idea Of My Car It Looks Alot Like A Gt2. I Have The Gts Spoiler,rooke 18" Wheels,front Spoiler Painted Color Of Car (artic Silver),hre Springs .inside I Have The Carbon Fiber Option. The Interior Color Is The Light Gray. Damm It Might Just Be Easer To Learn How To Post Pictures.
Old Aug 23, 2006 | 10:25 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
Paulie,
Try This -
Kevin (KPG) posted that at 70mph in 4th gear he floored the gas and got 1.2 bar in 3 seconds. I tried the same thing and had the same results. We both have K16/24 hybrids, but different tuners. It would be interesting to see what result you get with this test - however, I don't think it really means anything other than your turbos are able to produce full boost quickly.
Old Aug 23, 2006 | 10:31 PM
Billystang's Avatar
Billystang is infamous around these parts
Did you see big difference with the K24s?
i ordered a set yesterday!
Old Aug 24, 2006 | 07:48 PM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Originally Posted by John D II
Paulie,
Try This -
Actually John, it was 1.1 bar in 1 second. The video on youtube doesnt show the timer, but it is a 2 sec video and the 1.1 is there halfway thru. If you like I can email the source video with the timer and frame by frame analysis. Kevin
Old Aug 24, 2006 | 08:50 PM
Time For 1.2 Bar
I Did The 70mph Mash Test And I Also Get 1.2 Bar Within 3 Sec. My Set-up Includes Stock K24's, Evo Wastgates,giac Stg 3/4 Tuning, Fabspeed Exst,dv's,evo Intake Box.
Old Aug 24, 2006 | 08:52 PM
John D's Avatar
Hi Kevin,
Sorry for the confusion. When I floored the gas in 4th at 70, I hit 1.2 bar in the time I could say "1/1000"...about 1 second, also. I repeated it several times to be sure. Knowing that you and I both spool to full boost almost instantly at 70 in 4th, I think it would be reasonable to assume Paulie should see full boost rather quickly under the same circumstances. If he does not have K16/24, but full K24's, it may take him slightly longer...but I think he should be seeing 1.2 bar as long as his GIAC software is designed to boost that high (I believe it is).
Old Aug 24, 2006 | 08:57 PM
KPG's Avatar
KPG
Hi Kevin,
John, it is amazing what good turbos and programming can do ! Are your hybrids from Ultimate? Kevin
Old Aug 24, 2006 | 10:05 PM
tme's Avatar
tme
tme is infamous around these parts
I've been able to sustain 1.4 with stock K24's
Old Aug 24, 2006 | 10:10 PM
KPG's Avatar
KPG
Unless you have programming to bypass the TB shutdown at 1.3 bars, that isnt likely. Stock Giac Stage4 will not allow 1.4. What is your trick. Kevin
Old Aug 24, 2006 | 10:36 PM
PorschePhd's Avatar
K24s can not sustain 1.4 bar. They hardly will hold 1.2 for any length of time.
