Lack of linearity with stock clutch
Old Sep 5, 2006 | 11:28 AM
Bobby_P's Avatar
Bobby_P is infamous around these parts
So, I have this embarrassing little problem with my 05 TTs coupe. When leaving a stop light, because of the way the clutch holds, I am finding that I either slightly bog the motor or over rev. I have never experienced a clutch with the ‘feel’ of the TT.
If I upgrade to a new (ie., Sachs) clutch would this problem disappear, stay the same, or get worse?
Old Sep 5, 2006 | 12:30 PM
Zippy's Avatar
Bobby. You better stick with the stock clutch as it is dramatically more progressive than a LTWF/Stage 3 combo. BigBadBen's clutch https://www.6speedonline.com/forums/...ghlight=clutch is a different matter though. Very progressive and can hold big power.
Old Sep 5, 2006 | 01:05 PM
ebaker's Avatar
ebaker is infamous around these parts
It's typical of all diaphragm clutches.
Old Sep 5, 2006 | 06:35 PM
carendt242's Avatar
carendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the rough
i never really got used to the stock clutch.
the sachs 2 (w/ lwfw) was a ***** to break in but i got *very* used to it. i loved it - a dramatic improvement over the stock clutch.
the sachs 3 - i can drive it but it's nowhere near as fun as the sachs 2. yes, it snaps your neck when you powershift; but it's not much fun drivng around the city. you can either baby it and take off slow; or you have to commit to a very fast launch - there's not much in between.
- chuck
Old Sep 5, 2006 | 08:27 PM
Bobby_P's Avatar
I think I recall reading on the forum--although I can't find it using 'search'--that the GT2 clutch can be used in the 996tt and has a much better feel than the stock Turbo clutch...anyone know if this is correct?
Old Sep 6, 2006 | 12:53 AM
ebaker's Avatar
The GT2 uses the same pressure plate. The disc is a different part number but I doubt if the feel is different.
Old Sep 6, 2006 | 01:03 AM
Fabryce@GMGRacing's Avatar
Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !
The feel will remain the same- Regardless of what clutch you use-
The issue is that the clutch is assisted via a pressure accumulator- GT2 and GT3 are not - hence the different feel.
We have a clutch kit- that uses Sachs race engineering components-
Upgraded clamping force on pressure plate- Gt2 style disc. and all the other parts needed..
However the feel- will be the same.
So the only way to get rid of it is getting rid of the assist in the clutch system........
Old Sep 6, 2006 | 01:36 AM
BigBadBen's Avatar
BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !
Bobby,
Like Zippy said a triple disc is the business if you want a very progressive clutch set-up even with a LWFW like I have, its easy to drive and can hold buckets of TQ. The only downside is it's not cheap..$6K parts only. My set-up also does away with the hydraulic assist so it is like a GT2 now, about 30% more effort involved in depressing the clutch which I don't mine at all. I am very happy with my setup.
Old Sep 6, 2006 | 06:55 AM
kiko's Avatar
kiko is infamous around these parts
The pressure plate on the GT2/X50 (and GT3) has a different part number than the Turbo, at least here in Europe...
Does anyone know if the GT2/X50 clutch kit has springs or not? Is the lining different?
Old Sep 6, 2006 | 07:19 AM
SMR's Avatar
SMR
SMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the rough
Go to a gt2 setup, trow the servo assistence away
Old Sep 6, 2006 | 10:05 AM
aj996tt's Avatar
aj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond repute
X50/Turbo S has GT2 plate but same assist as Turbo. When my clutch goes a little more bad, I'll go to a complete GT2 setup or stage 2 Sachs. Key is getting rid of the assist.
Old Sep 6, 2006 | 10:08 AM
sechsgang's Avatar
sechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant future
i find the assist pretty annoying too...
Old Sep 6, 2006 | 11:26 AM
spidey's Avatar
spidey is infamous around these parts
Getting rid of the assist
Has anyone actually done this ?
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
brockster
Jan 22, 2016 12:18 AM
Vrseis
Aug 20, 2015 07:41 AM
