Front end Vibration
Old Sep 19, 2006 | 05:17 PM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
With ROad force feature like 100 for all 4 with out road force and regular point balancing I would say 60-80 good luck youll be fine. Get some nice race wheels on the car!
-Suman
Old Sep 19, 2006 | 07:13 PM
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
Originally Posted by Highhats
Sounds liek you run a very soft tire. Tires when driven hard and then sitting or washed with a cold water can flat spot slightly which usually takes about 20 minutes to get rid of on your next drive. Is this the case does the shaking go away after a short while?
-Suman
i never knew you can drive out a flat spot... you really can?
Old Sep 19, 2006 | 07:19 PM
Highhats's Avatar
You can drive out a flat spot created by stopping a car in a garage from a soft tire but I doubt you can do the same with a large flat spot from locking hte brakes and skidding, those are super deep.
-Suman
Old Sep 19, 2006 | 08:03 PM
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
If it's not the tires or wheels, check the front wheel bearings and the front differential.
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
BLOWN SRT
Aug 25, 2015 01:28 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
