How much power does GT2 IC's on a stage 2?
Old Sep 19, 2006 | 07:23 PM
kiko's Avatar
kiko is infamous around these parts
Has anyone dyno'd a before and after ( or has a rough idea) of how much power they're good for on a typical "stage 2" running 0,9-1,0bar?
EDIT: Would a Moderator please edit the title for misspelling?
Old Sep 19, 2006 | 07:29 PM
sharkster's Avatar
hey kiko.. the flow is the same since they are the same end tanks and sized cores... However, the fins do protrude outwards and apparentely Porsche claims they're 3% more efficient... If you want IC's that flow more and give you more power: http://www.sharkwerks.com/products.php?pid=64
Old Sep 19, 2006 | 07:42 PM
kiko's Avatar
But I thought I read somewhere here on 6speedonline that your IC's would be overkill for a mere stage 2...
Old Sep 19, 2006 | 07:50 PM
sharkster's Avatar
For stage II they would kiko.... Better flow is always great but I'd do other upgrades first
Old Sep 19, 2006 | 07:54 PM
you don't need them at this level.... do some turbos first....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Sep 19, 2006 | 08:10 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
kikoi got the gt2 after a long time conversation regarding maintaining boost levels in hot weather i remember 10 percent more cooling ..... went for kevins k16s and other up grades was hopeing for more with the 4000,00 upgrade to evo.....no dyno yet.. seat of the pants dyno a mild increase maybe i need to drive more to let the ecu learn .
Old Sep 19, 2006 | 08:13 PM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Steve, how do these IC's affect your programming? Plug and play or does the ecu need to be tweaked? 4k and you need the ECU to learn? Kevin
Old Sep 19, 2006 | 08:45 PM
todd at evo said no reprogram.... am sure it takes 5 hot and cold starts for the ecu to learn..... so i have been told
Old Sep 19, 2006 | 08:52 PM
KPG's Avatar
KPG
Steve, to learn what? There is less pressure drop, less heat soak, more flow? I assume you have done the 5 hot and cold start? How does it feel? Is this a mod that can only be felt on a dyno or during a long ,hot day at the track that would heat soak the stock IC's. Just curious on some real world feedback because I am interested. Kevin
Old Sep 19, 2006 | 10:17 PM
iLLM3's Avatar
Im almost 100% positive it wont be felt by just swapping intercooler's on, its really just for better airflow efficiency which results in less heatsoak. Same with the nitrous intercooler setups, cant be felt unless doing runs in hot weather like you mentioned!
Old Sep 19, 2006 | 10:36 PM
oak's Avatar
oak
you need them. your missing out on the full potential of your set up.
Old Sep 20, 2006 | 08:52 AM
WOODTSTER's Avatar
Oak,
you are joking right?
I cannot ever tell with you...
MK
Old Sep 20, 2006 | 11:58 AM
sharkster's Avatar
You need ME
Old Sep 20, 2006 | 01:36 PM
Bill in Atlanta's Avatar
Bill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud of
Oak, you're killing me on the Rennlist "Evo airbox" thread !!!
Bill
Old Sep 20, 2006 | 01:41 PM
oak's Avatar
oak
I apologize, some times I can't help putting my .02 from the "peanut gallery". some of the guys have such a hard on. I can't resist. I mean no harm.
