Max Tire Width w/ on Stock Wheels?
Old Sep 20, 2006 | 05:45 PM
split's Avatar
split is infamous around these partssplit is infamous around these partssplit is infamous around these partssplit is infamous around these parts
Question Max Tire Width w/ on Stock Wheels?
So I have the stock wheels on my '05 Turbo S and I'm wondering what the widest tires I can on them without rubbing is?
Right now I'm eyeing up the Yokohama A048 tires and I found that the came in the following size:
235/40QR18
315/30QR18
is that going to fit or is that too large? The total diameter is going to be a tiny bit taller too so its going to raise the car up a bit.. is that going to be a problem?
Old Sep 20, 2006 | 06:11 PM
gneypiks's Avatar
gneypiks is infamous around these partsgneypiks is infamous around these parts
I am running MPSC tires in those sizes with oem 996tt rims.Under hard acceleration the inside will rub a little-does not bother me as i visually check them after each track day.
Old Sep 20, 2006 | 06:55 PM
wross996TT's Avatar
Should be no problem...I'm running the same as gneypiks and Michelins run big...so Yokos should be just fine. Let us know how you like them please.
Old Sep 20, 2006 | 08:22 PM
split's Avatar
Question
the inside will rub? Do you mean like the inner fender, or on like the strut housing?
And what rubs, the front tires or rears?
Old Sep 20, 2006 | 08:37 PM
gneypiks's Avatar
Only the rears.It rubs on the plastic wheel liner,again another factor is what kind of suspension set up your car has.Mine is lowered with coilovers n cambers are adjusted.
Old Sep 20, 2006 | 10:25 PM
tom kerr's Avatar
sizes are fine!
Old Sep 20, 2006 | 11:53 PM
split's Avatar
Lightbulb
lowering shouldn't change whether or not you'll rub or not. It just gives you less suspension travel. I the end at some point you'll use up your entire suspension travel, but with a lowered car it will happen sooner.
Old Sep 21, 2006 | 10:21 AM
WOODTSTER's Avatar
I run 245 Hoosier S6 on the front of my car, on stock wheels.
MK
Old Sep 21, 2006 | 04:04 PM
split's Avatar
i don't want any rubbing at all. What about 305/30QR18
tires then? Also is there any way to roll that plastic wheel liner or something so I don't have to worry about rubbing?
Old Sep 21, 2006 | 05:23 PM
Griza's Avatar
Griza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud of
shouldn't the rears be 315/25? He has them listed at 315/30.........
Old Sep 21, 2006 | 07:08 PM
wross996TT's Avatar
To repeat...I have MPSC 235/40 18" fronts and 315/30 18" rears w/PSS9 suspension and DO NOT RUB at all!
Old Sep 23, 2006 | 03:33 PM
cmalana's Avatar
cmalana is infamous around these parts
Looks like the consensus is that 235/40R18 fronts and 315/30R18 rears work well, especially with an adjustable suspension. Besides the stock wheels, anyone have any recommendations on a good set of wheels for street and occassional track use?
There are so many choices out there but wanted something light, strong, and reasonably priced for days I don't want to be on very low profile 19" wheels! Preferably something you can get that's black with a polished lip!
Old Sep 23, 2006 | 03:35 PM
split's Avatar
Exclamation
i would have thought 315/25QR18 would have been closer to the factory diameter as well, but I can't find any tires that come in that size. Only 315/30/18. I think I may just go 305/30/18 to be on the safe side. the Yokohama AO48's come in that size as well, and they look like they'd be pretty grippy.
Old Sep 23, 2006 | 03:59 PM
Griza's Avatar
I think that is a wise decision..........
Old Sep 23, 2006 | 06:19 PM
wross996TT's Avatar
MPSC...awesome!
COBB Tuning
Jan 1, 2025 09:02 AM
Enemy
Nov 10, 2015 08:01 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
ModBargains
Aug 20, 2015 12:28 PM
oddjob142
Aug 19, 2015 12:27 PM
