HELP! new sparkplugs installed, WIERD at IDLE!
Old Sep 21, 2006 | 10:56 PM
oak's Avatar
oak
loose hose.
Old Sep 21, 2006 | 10:57 PM
ebaker's Avatar
ebaker is infamous around these parts
Sounds like one of the hose ends slipped out. It's hard to get the big hoses pushed fully into place. Be sure the retaining spring wire clips are fully down in their grooves. Make sure the hose ends are pushed in and latch with an audible click.
Old Sep 21, 2006 | 11:17 PM
CarreraMark's Avatar
CarreraMark is infamous around these parts
Originally Posted by MARKSKI
Ist most probably the coil packs.. u forgot to hook up the wire to the coil pack and ur running on 5 cyl. I happened to me... Im sure of it...
u see the coils are screwed on the engine so that cant be the problem... its the wire thats is not put into the socket of the coil pack.
I put $100 on this one LOL
Been there, done that, got the t-shirt. the good news is it goes faster the second time!
Old Sep 22, 2006 | 02:00 AM
check the hoses that go from the turbo to the intercooler under the car...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Sep 22, 2006 | 06:39 AM
AIRjordan23's Avatar
AIRjordan23 is infamous around these parts
the hoses are in. i dont understand, is thier a click i should be hearing here too?
Old Sep 22, 2006 | 07:16 AM
kiko's Avatar
kiko is infamous around these parts
Make sure the O-rings are not pinched.
Old Sep 22, 2006 | 08:28 AM
pardon my ignorance but where can I find these o rings so I could check.
Old Sep 22, 2006 | 08:35 AM
ebaker's Avatar
They are on the ends of the big intercooler hoses.
Old Sep 22, 2006 | 11:53 AM
the intercooler connections are tight. I made sure they are in all the way. ill make sure again. in genral since I installed the plugs theproblem has to be one of the components that were taken apart and reassembled. that's what my logic tells me. however I still can't find the problem.
Old Sep 22, 2006 | 12:03 PM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
Plugs will not cause idle hunting...no matter how out of specs they are. You would get a misfire if the problem was with the plugs. If a plug was physically broken, you would get a misfire and hear the exhaust from the broken plug. Did you disconnect the battery anytime during your installation?
Old Sep 22, 2006 | 12:17 PM
no I did not disconnect the battery at any point. I agree with you and other members about it not being related to the plugs.
Old Sep 22, 2006 | 01:12 PM
iborroel's Avatar
iborroel is infamous around these parts
Originally Posted by tom kerr
boy am I glad I had this done at the dealer!!!
I 2nd that.
Old Sep 22, 2006 | 01:33 PM
oak's Avatar
oak
loose hose.
Old Sep 22, 2006 | 04:07 PM
02barebones996's Avatar
02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute
air leak ....
Old Sep 22, 2006 | 04:29 PM
pull on the hoses on the bottom of the ICs... see if they slip off....
run the car without the bumper at night so you dodnt have to take it off again.. get on it and you should find out very quickly of the problem went away....
9.66
click to view
