Trans Troubles???
Old Sep 29, 2006 | 11:20 PM
Turbochris's Avatar
Turbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond repute
Trans Troubles???
Jeezzz, I hope not.......3 days ago...sitting at a light....light turns green...I blip the throttle and as I start to let out the clutch about an inch, POP...my shifter jumps out of first......
Fast forward.....the next day......it does it three times.......and about three times a day since.......
So, of course, I've heard about the popping out of gear upon DECEL........ands that necessatates a $6000 rebuild.....but I've never hear of it popping out when I blip the throttle and BARELY let out the clutch...I mean the car hasn't even started to move at ALL.......
I seem to recall someone having something simular happening and it ended up being a cable adjustment?
Opinions??
****.....hoping this isn't gonna drastically cut into the mods budget......
Chris
Old Sep 30, 2006 | 02:39 AM
iLLM3's Avatar
Damm man crazy, haven't heard of that issue before! I hope its nothing to serious especially cost wise , goodluck man
Old Sep 30, 2006 | 08:39 AM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
I would think the linkage is not properly aligned. Sounds like when you are in first gear, it is not engaged 100% (shift linkage off) and causing the car to jump out of gear.
I am not a pro, but am just hoping that is the issue, and easy fix. I have never heard of a 1st gear issue on the turbos.
adnanm3
Oct 25, 2016 08:38 AM
Glasgo
Nov 30, 2015 02:37 PM
Oct 2, 2015 02:23 PM
