Thoughts on EVOMS Swift Shift Kit???
Old Oct 23, 2006 | 08:11 PM
9Eleven's Avatar
9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute
Originally Posted by Zippy
Is it a short shifter or a shift linkage?
I believe it's a linkage.
Old Oct 23, 2006 | 09:05 PM
msv's Avatar
msv
msv is a splendid one to beholdmsv is a splendid one to beholdmsv is a splendid one to beholdmsv is a splendid one to beholdmsv is a splendid one to beholdmsv is a splendid one to behold
It consists of a machined piece that slides over the ball-end of the orignal shifter (lengthening it) and is affixed with a set screw. Upon this piece there is a rod-end with spherical bearing. Into this screws the cable end replacement that attaches to the original cable shaft with 3 set screws.
Additionally it replaces the bushings that the shifter operates in with needle bearings in billet housings.
Old Oct 23, 2006 | 09:48 PM
Chasen1211's Avatar
Chasen1211 is a jewel in the roughChasen1211 is a jewel in the roughChasen1211 is a jewel in the rough
my dad ordered a Porsche SSK a few days ago, so it should arrive end of this week or beginning of next...very intresting reading...lots of info on the different options out there...
Old Oct 24, 2006 | 02:12 AM
D-UberCars's Avatar
D-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud of
I have the B&M SSK and the EVO shift link. Love them both. Tight, shorter shift and positive feel. Only slightly notchier but, with definite click in each gear. You'll love this mod.
Old Oct 24, 2006 | 10:57 AM
rcalcaide's Avatar
rcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud of
Yeah... my car is a daily driver, and I didnt want something that created more effort to drive. So Im seriously considering the the EVO swift instead of SSK. Seems to be a good compromise between stock and true SSK. Now the question is can I install myself or bring it to my mechanic.
Old Oct 24, 2006 | 11:11 AM
msv's Avatar
msv
It is a pretty easy install, IMHO, but I always do my own work. If you are used to doing your own wrenching, then go for it.
Old Oct 24, 2006 | 11:20 AM
Bodybag's Avatar
Bodybag has a spectacular aura aboutBodybag has a spectacular aura about
Originally Posted by Bodybag
For what it's worth, it was a simple job I did in the garage in less than an hour. Instructions were super easy to follow and the install doesn't have any difficult steps.
I'll stick by this. No special tools or anything. Basically you're just going to remove about 8-10 screws that hold the console down, take it out, unplug a few wires and remove the shifter from it's housing. Replace it with the new shifter and put it all back together. You'll have the whole thing done in an hour or less.
Old Oct 24, 2006 | 03:07 PM
bli8's Avatar
bli8 is infamous around these partsbli8 is infamous around these parts
I had the B&M short shifter install in my GT3 and it greatly reduced the travel also, but the shift effort is a bit higher and notchy. Does anyone have detailed instructions on how to adjust the linkage?
OldBoldPilot
Aug 24, 2015 04:00 PM
johnny.dangerous
Aug 21, 2015 10:48 AM
Aug 21, 2015 06:34 AM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
