Tire & Rim Fitment Question
Old Oct 14, 2006 | 10:46 AM
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
Hey!
Will 225/40 R18 fit on a 8.5*18mm and 265/35 R18 fit on a 18*10.5 wheel?
I think there is a online tool that u can use to see if a certain tire will fit on a certain wheel width, but i wasn't able to find it.
Thanks!!
Regards,
Jason
Old Oct 14, 2006 | 10:53 AM
yellowturbo's Avatar
yellowturbo is infamous around these parts
They'll fit (tire section width will be wider than the wheel width in both cases).
However, why wouldn't you want at least 285 in the rear?
Old Oct 14, 2006 | 11:14 AM
angldrkns9's Avatar
thanks for the help!
they are my snow tires =)
Old Oct 14, 2006 | 11:17 AM
that explains it!!!
I have never lived in a place that required snow tires...(thank goodness).
Old Oct 14, 2006 | 12:21 PM
Joe Weinstein's Avatar
DANGER DANGER! Be very wary of
any online tire fitment calculators.
Please never use the 225x.45= 101mm style of formula ever, especially
for competition tires or for close fitment tolerances. Even for street tires
they are only approximate and for race tires they are less than a 'serving
suggestion'. I have seen two 245-45-16 street tires differ in diameter by
close to .5", from the *same* manufacturer! They were different model
tires.
All the online tire size calculators are based on the formula idea and
they are all very approximate as far as real tires are concerned. The only
way to know the real dimensions or recommended fitments of the tire is
to consult the vendor's tire spec sheet.
Hoosier used to make a DOT 305-30-18 tire. They don't anymore. They
now make a 315-30-18. *IT'S THE SAME TIRE*. This year they just decided
that all these years that tire's dimensions were actually closer to the
315-30-18 meaning than the 305-30-18 that they had been imprinting it
with, so they simply changed the lettering on the sidewall.
HTH,
Joe Weinstein
Old Oct 14, 2006 | 02:28 PM
angldrkns9's Avatar
tires.
HTH,
Joe Weinstein
interesting.. thanks for the info!
COBB Tuning
Nov 9, 2015 08:02 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
Aug 21, 2015 09:56 AM
ModBargains
Aug 20, 2015 12:28 PM
Aug 19, 2015 06:35 PM
