p0491/2 code??
Old Oct 19, 2006 | 01:59 PM
esemes's Avatar
esemes is infamous around these parts
Lightbulb p0491/2 code??
fellas.........
got a code today (my first) after washing the car, and it came up as
"p0491" and "p0492"
car ran fine, but i cant seem to figure it out....
i believe it is related to the "secondary air source; L and R bank".....
can anyone help me understand this better (before a dealer trip is in order???)
i did a battery-reset and the code cleared, but i can't be sure it wont come back (or why it did in the first place)
much thanks
-ese
Old Oct 19, 2006 | 04:34 PM
esemes's Avatar
SELF-REPLY No.213A
welp, i found a slice in the (aft) vac. line coming from my evo d/v....
it was just staring at me - defiantly.........
i replaced the line (from the backside of the tee) and am gonna drive her sometime tomorrow...
thanks for the support, Marc S........
will keep you all posted........
ese
Old Oct 19, 2006 | 11:44 PM
Zippy's Avatar
P0491 - Secondary Air Injection System, Bank 1 – Below Limit
Diagnosis conditions
- Intake air temperature 4.5 - 60 °C
- Engine temperature 4.5 - 102 °C
- Mass air flow 36 - 150 kg/h
- Engine starting temperature less than 42 °C
- Altitude correction factor greater than 0.75
- Oxygen sensors 1 and 2 ahead of TWC are ready for operation
- The secondary air injection pump is switched on
- Diagnosis has not yet taken place during this cycle
Possible fault cause
- Secondary air injection pump is not triggered
- Secondary air injection pump does not work
- Air supply lines restricted
- Electric change-over valve does not function
- Air change-over valve does not function
- Vacuum system leaking
Affected terminals
III/11 and III/14
Glad to see you got it figured!
Old Oct 20, 2006 | 08:04 AM
esemes's Avatar
Affected terminals
III/11 and III/14
Excellent info, ZIPP.........
thanks for the data; (where the heck do ya find it, anyway??)
crossing fingers that i've solved it........ (will know better after a longer drive today or this weekend)
will report back!
-ese
edit:: rep added!
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
PelicanParts.com
997 Vendor Classifieds
Oct 5, 2015 01:07 PM
Oct 2, 2015 02:23 PM
nagual911
Oct 1, 2015 01:52 AM
