RWD conversion
Old Oct 23, 2006 | 10:01 PM
rwm514's Avatar
rwm514 is infamous around these partsrwm514 is infamous around these parts
RWD conversion
Just about to go through with this. Any last minute thoughts on the issue? Illm3 and usctrojanman, I know you guys did it a while back, any regrets or things to think about before going thru with it? Should I just get the front drive shaft disconnected first or is this a waste of time? I live a couple of hours away from the shop so it would be 2 big trips instead of one. TIA
Old Oct 23, 2006 | 10:04 PM
iLLM3's Avatar
I would have the front driveshaft disconnected to see how you like it. My thoughts? It totally transforms the car, the feel and so on. Even with the driveshaft disconnect its instantly different feeling, sounds crazy but its true. See how you like it first then go from there, traction issues should not be an issue one bit.
Old Oct 23, 2006 | 10:31 PM
rwm514's Avatar
Its hard to believe it will make much of a difference, cant wait!
Old Oct 23, 2006 | 10:35 PM
cjv's Avatar
cjv
Moderator
Handling wise it is not good. You are carrying all the extra weight with the tranny and the front differencial and have none of the advantages.
Old Oct 23, 2006 | 10:36 PM
iLLM3's Avatar
Take my word for it and believe me, cant wait to hear your impressions
Old Oct 23, 2006 | 10:37 PM
Turbo Fanatic's Avatar
Ditto what Ill said. The front drivetrain gets 5% of the torque at all times so you will feel more power as well.
I don't feel the need to remove all the components. It will save 130lb, but removing the driveshaft is reversible in 15 mins.
Old Oct 23, 2006 | 11:05 PM
rwm514's Avatar
I think you are referring to just disconnecting the front driveshaft. Are you?
Old Oct 23, 2006 | 11:06 PM
rwm514's Avatar
Is the 5% a subtle difference or is it pretty noticeable?
I will be taking it to the drag day event, dec 2nd here and should be able to get some #'s for everyone.
Old Oct 23, 2006 | 11:10 PM
iLLM3's Avatar
Its VERY noticeable, not just from the power or torque but steering feel when it was disconnected. I dont know how, but it felt more alive and responsive, just try it out, you will be shocked!
Old Oct 23, 2006 | 11:13 PM
rwm514's Avatar
Ill be reporting soon!
Old Oct 23, 2006 | 11:17 PM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
I agree with Martin, I just popped off my front driveshaft today because I am going to the dyno tomorrow. Unfortunately it is raining pretty hard and there is zero traction, but I did notice that the steering feels lighter... and that was backing out of the garage. Took 35 min start to finish. Give it a shot. As for the difference for your drag day, I am running AWD and RWD tomorrow...same car, same dyno, same day. I will give you pretty hard numbers on the difference tomorrow. Kevin
Old Oct 24, 2006 | 12:03 AM
iLLM3's Avatar
Kevin i cant wait to see the times and results, goodluck and be safe!
Martin
Old Oct 24, 2006 | 02:05 AM
I can't wait to see the results as well...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Oct 24, 2006 | 02:15 AM
FAT-911's Avatar
FAT-911 is infamous around these parts
When you disconnect the front driveshaft, doesn't it trip the CEL and ABS lights etc?
Old Oct 24, 2006 | 02:29 AM
notquitefob's Avatar
notquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud of
subscribed = )
