Tire pressure advice
the above is a good place to start for street driving. If it gets much more spirited I would start checking tire pressures. I went out on the track with the tires you have and started at the above settings. came in and rears were 55psi!!
I keep them at 40 hot at the track. other wise you are pretty safe with the manufactures recs
I always check tire pressure before going on a run but never right after, it would be interestng to see the change.
Tony, I think if you check them you will really be suprised!! I actually ruined a rear set at the track by being "careless" The side walls dont take much out of the range recommended. that includes too low or high.
Jul 29, 2019 11:13 AM
RallyBird
Oct 7, 2015 01:20 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
