Anyone do the EVOMS throttle body Kit
Old Nov 1, 2006 | 08:08 PM
  #31
thats what a few smarter guys then I told me...
but then not all tuning kits are alike...
there has been only a handful of bent rods... and they were boosting about 1.5 bars or higher with larger turbos....
the trick is to have a system that can produce the HP figures at lower levels ..
so u run bigger(not huge) turbos with less boost.. thus requiring less fuel...
then u do some decent piping and cooling to add efficiency.... thats it...
its more obvious then we tend to believe...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Nov 1, 2006 | 08:09 PM
  #32
Originally Posted by steve harris
me no want high boost wanna be safe what do you suggest for more hp at present am running europipi loud, s cargo headers small tubes, evo hoses and new ics, evo air box,giac proram, pump and 100oct,...
and u have kevins k16/24 hybrids? and probably a stage 3 giac ecu?
9.66
click to view
Old Nov 1, 2006 | 08:16 PM
  #33
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
we took about five tries to get theprogram correct really don't remember what stage will check it out wed this week....have always been a big air flow fan thats why the y pipethought but have been discourages dur to the 16's
Old Nov 1, 2006 | 08:29 PM
  #34
not since the giac , and the new ics seems very quick seat of pants dyno
Old Nov 1, 2006 | 08:34 PM
  #35
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Steve, if you ever make it to the dyno , ask the operator to put a thermocouple in the IC inlet. I drove my car on the dyno last week and had my hand out the window feeling the air blowing out the IC inlet... since fans were blowing in the IC outlet. When I got into the boost , the air felt like a hairdryer. We had a starting temp of 67deg and when we finished the run it was 180deg. I would love to see how those big IC's would do in a similar test. Kevin
Old Nov 1, 2006 | 08:43 PM
  #36
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
For the guys with Evoms setups you can also get this enlarged y-pipe and 76mm TB.
Old Nov 1, 2006 | 08:46 PM
  #37
NICE now I know why ur running so fast
9.66
click to view
Old Nov 1, 2006 | 09:00 PM
  #38
kevin will do hopefully next week
  #39
a good excuse to take the front drive shaft off
Old Nov 1, 2006 | 09:01 PM
  #40
joetwint's Avatar
Mark, the y-pipe is new and wasn't on there when it was a 700.I had the 76 mm tb and modded stock y-pipe before but with no software change for it.I just bolted them on and didn't know there was a software change that would help me utilize the new hardware.Oh well, live and learn.
Old Nov 1, 2006 | 10:33 PM
  #41
Zippy's Avatar
Joe - I hae the modded stock Y-Pipe & 76mm TB. Do you think there is any bennefit going to the enlarged Y-Pipe? Does it use the same file as the modded OEM Y-Pipe?
Thanks, Mike
Old Nov 1, 2006 | 10:51 PM
  #42
joetwint's Avatar
Thanks, Mike
I don't think it can hurt and I would do it in conjunction with Evoms larger intercoolers,if you haven't done them already, because it requires the boost hoses for the larger intercoolers(no o-ring).I don't think it requires different programming but you should ask Todd,Sharkster or PorschePHD(Stephan).Looks cool as hell though!!
Old Nov 1, 2006 | 11:10 PM
  #43
cjv's Avatar
cjv
Moderator
Thanks, Mike
Your power is no stronger than it's weakest link. In order to make power with a weak link you have to increase boost.
Intake air capacity, IC efficiency, hard piping size vs hoses, Y pipe size, throttle body size, splitter vs plenum, intake ports, valve size, cam lift/duration, exhaust are all links. If they are not matched all you do is create an obstruction or dam which requires additional boost to make more power. If you happen to be improving the weak link, you will make power up to the point of the next weak link. That's why a motor that creates more or equal power at a lower boost is a better or more efficient motor.
It is rather comical to watch people beef up one are only to find a restriction in another without given thought to the air flow of each individual component. These motors are really nothing more than an air pump with fuel added in the proper proportion of air or oxygen.
The real question comes down to was your motor designed or is it one guess after another?
Old Nov 2, 2006 | 01:16 AM
  #44
Divexxtreme's Avatar
Originally Posted by MARKSKI
Im sure there is some... maybe you can convince them to do this
76 MM TB with splitter... custom MAF and housing
Hey...that looks just like mine! Except mine's red.
Old Nov 2, 2006 | 02:05 AM
  #45
Scott,
HA HA I know...
CJV- awesome write up...
9.66
click to view
