2002 GT2 - Front End Rattle???
Old Nov 3, 2006 | 10:08 PM
Bodybag's Avatar
Bodybag has a spectacular aura aboutBodybag has a spectacular aura about
Does anyone know if this is a common issue with the '02? When I drive it feels like something is loose in the front suspension. The steering is tight with no play, as well as the brakes. It just has a cluck sound that you can kinda feel when traveling over small bumps. It gets way worse at very low speed.
Anyone???
Old Nov 3, 2006 | 10:11 PM
20C4S's Avatar
sounds like ur swaybar is loose. if not the swaybar check the brake cooling duct. those plastic ducts come off easy.
Old Nov 3, 2006 | 10:16 PM
vincentdds's Avatar
vincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond repute
It does that when your sway bar is being set at its softest setting. Also the springs do make noises on bad roads.
Old Nov 3, 2006 | 10:21 PM
Bodybag's Avatar
This is clearly a "clunk". Could be the swaybar endlinks I guess? I was just wondering if this was a known issue, or something unique to my car.
Old Nov 4, 2006 | 10:59 AM
JASCLASS's Avatar
JASCLASS is infamous around these partsJASCLASS is infamous around these parts
Im with all on the sway bars being loose.
Old Nov 4, 2006 | 06:12 PM
9Eleven's Avatar
9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute
Had the exact same noise. Removed the front sway bar and it went away. Put it back on, tightened down the sway bar drop links and problem solved.
Old Nov 5, 2006 | 12:02 AM
iLLM3's Avatar
Exactly what it is!
2lflat4
Nov 18, 2019 05:05 PM
Enemy
Nov 10, 2015 08:01 AM
SharkyShark20
Sep 19, 2015 09:54 PM
TrackOne
Aug 20, 2015 12:56 PM
m_motorsport
Aug 19, 2015 03:34 AM
