996 TT MEF problem??
Old Nov 11, 2006 | 10:54 PM
halley's Avatar
halley is a splendid one to beholdhalley is a splendid one to beholdhalley is a splendid one to beholdhalley is a splendid one to beholdhalley is a splendid one to beholdhalley is a splendid one to behold
I have a 996TT with an k&N airfilter. Couldn't drive it to much in the last time so within the last 6 months the battery went dead 4 times. I took the car out today and had to learn, when it was warm that it nearly never reaches more than 4000 rpm instead it fires strange and has no boost at all. Is it possible that over the time something happened to the Mef?? I have the car from the beginning(2001), and had never such problems. How can I clean the Mef??
Old Nov 11, 2006 | 11:41 PM
wross996TT's Avatar
You mean MAF? If the MAF (mass air flow sensor) is blown cleaning it wil not help. I know many have posted about cleaning it, but I have not seen any measured improvement by doing this. If you are are not getting cels, perhaps your plugs need changing? For the MAF procedure:
http://www.renntech.org/forums/index...pic=414&hl=MAF
Old Nov 12, 2006 | 02:34 AM
Zippy's Avatar
If your K&N has been over oiled, it could be messing up your MAF. That being said, I am using a K&N filter in the OEM air box without issue.
Old Nov 12, 2006 | 07:22 AM
halley's Avatar
Jap, MEF, sorry, was to late yesterday. Thanks for the link. Two more questions, what should I take to clean the K&N filter and is it possible to change the plugs by myself or have I to go to the service? ( didn't touch a wrench in a century, but would like to again).
Old Nov 12, 2006 | 11:40 AM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
you may be in lip mode .. unhook your batt for 15 min. also run down to your ace hardware store get some elec cleaner ... remove your maf and spray it let dry install and i bet all will be fine ... worked for me same symtoms.
Old Nov 12, 2006 | 11:08 PM
killerbee's Avatar
killerbee is infamous around these parts
I think you mean limp mode...Or maybe its supposed to be funny. General rule is if you can't spell it then you probably do not know what it is and should just take it to the dealer.
tropicatango
Jun 8, 2025 01:00 PM
2lflat4
Nov 18, 2019 05:05 PM
Jojore9
Sep 30, 2015 05:11 PM
gulf gt
Aug 27, 2015 10:27 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
