Boost
Old Feb 12, 2004 | 09:15 AM
MiamieNeSeX's Avatar
MiamieNeSeX is infamous around these parts
Boost
I am curious as to how much boost you guys are running both stock and with upgrades. Also do you use the factory ECU, some sort of piggy back system or a stand alone like Motec or AEM.
Armando
Old Feb 13, 2004 | 06:16 AM
Is the factory ECU feild programable (a/f ratio timing, etc)? I read on your board that some go with bigger turbos, I would think that throws the factory ecu out the window.
Armando
Old Jul 2, 2004 | 06:04 AM
94RX-7's Avatar
94RX-7 is infamous around these parts
Originally posted by Ruiner
AEM is a great stand-alone, but it is geared more for the Japanese (Supra, 3000GT, 300zx, RX-7, etc) market.
I was thinking the same thing. I don't think that AEM or Motec make anything for cars other than a few domestics and Jap imports.
Old Jul 2, 2004 | 07:53 AM
Orli930's Avatar
Orli930 is infamous around these parts
1.2 Boost constant and peaks for a sec at 1.3. I am not running factory Turbos.
Old Jul 2, 2004 | 08:19 AM
FAST3's Avatar
FAST3 is infamous around these parts
Is there a big lag difference between a stock 0.7 to a 1.0, 1.2, 1.4 bar?
Old Jul 2, 2004 | 09:07 AM
Periokid's Avatar
Periokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud of
It depends on which turbos you are using.
I have stock turbos (non x-50) and I run 1.0 bar with rare peaks to 1.1. Since they are stock turbos, the lag is the same.
Bigger turbos may have more lag.
Emre@Esmotor
Oct 19, 2015 12:06 PM
whtrabt
Oct 5, 2015 05:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
