Shark Werks: 996TT GT800 Project "Great White" #2
So is this a secret? I'm asking for sizes and offsets..
PM me if you would rather keep it private?
Realistically, I'm wondering how wide I can go with GT2 spec wheels. I'm already running them with 315s and a 7mm spacer and there is some room to play with both inside and out.
How about the fronts? What sizes are you running there? I run 255/35 on stock 8" twists, have yet to try them on my GT2 8.5" wheels but i bet they fit no problem.
PM me if you would rather keep it private?Realistically, I'm wondering how wide I can go with GT2 spec wheels. I'm already running them with 315s and a 7mm spacer and there is some room to play with both inside and out.
Yup 335s in the rear is right (RA-1s). My offsets are really pretty out there on the edge so I honestly _wouldn't_ follow them unless you're starting with a GT2 or have a lot of fancy adjustable suspension/control arms. You'll otherwise be stuck with wheels that stick out a bit beyond the fender
HRE has them but off the top of my head we went with GT2 specs plus 4mm in the front and plus 6mm in the rear if I remember right....
Thanks man. So running 335 / 245s?
Hey Alex, curious with the larger 335's seems like you are limited to suspension set ups as the space get's pretty cramped and doesn't allow enough room to tweak your settings. Seem like with 335's your window of tweaking is very small.
It's not something I'd recommend ***** nilly
hey fellas just a heads up for you guys in Europe but apparently this month's issue of Total 911 ( www.total911.co.uk ) is out and features our Great White GT800 in it. According to SnowBoarder the midnight shots look pretty trick too:P Stevo or any of you UK guys seen it yet? I didn't get a copy yet so...
hey fellas, looks like she's going to be going to a new home and soon. Going to put her back to stock-ish (around a Stage II) so if there's any parts you guys want let me know because I'll be pulling most of the stuff off
I know pal... I'm not just saying this either
But I have two other cars coming in soon and to stop the shop from being filled with um... my cars instead of customer cars this one is a casualty;(
