Proper way to install GT3 seats
Old Dec 2, 2006 | 05:46 PM
livetoshift's Avatar
livetoshift is infamous around these parts
I am installing GT3 seats in my 996tt and I thought I had heard that there is an issue with getting an error code if you don't do something right. Is it as simple as don't turn the iginition on on something like that? Is there any thing else to watch out for?
Old Dec 2, 2006 | 05:50 PM
habitat's Avatar
Senior Member
habitat is just really nicehabitat is just really nicehabitat is just really nicehabitat is just really nice
I think you have to disconnect the battery first before removing your stock seats. Then once the seats are out and GT3's are in, connect the battery and you are ready to go.
This is what i did and had no lights come on.
Good luck
Old Dec 2, 2006 | 07:37 PM
vipertestarossa's Avatar
vipertestarossa is a jewel in the roughvipertestarossa is a jewel in the roughvipertestarossa is a jewel in the rough
disconnect the battery and do not turn the ignition on with the seat wiring harness off or else you will get an airbag failure light
Old Dec 2, 2006 | 11:54 PM
tthoang1's Avatar
tthoang1 is infamous around these parts
I know this is totally obvious, but make sure the doors are unlocked when you disconnect the battery and don't close the bonnet.
Old Dec 3, 2006 | 08:14 AM
live2shift's Avatar
live2shift is infamous around these parts
Thanks for the tips. I will unlock the doors, and disconnet the battery, but I don't want to close the Bonnet after I disconnect the battery or it will be a PIA to open it again correct?
Old Dec 3, 2006 | 08:17 AM
don't close the bonnet.....
Old Dec 3, 2006 | 09:09 AM
BBGT2's Avatar
BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !
Yeah you wouldnt want to close the bonnet, thats where the battery is and you wont be able to open it without battery power. Which will force you to charge/boost the battery so you can open the hood/onnet whatever you wanna call it.
Also after you disconnect battery, wait at least 3 minutes before disconnecting any connectors on the stock seats, this is needed for the diode to charge down, thats what I have been told in the past to do with any airbag systems.
Bajo
Old Dec 3, 2006 | 09:20 AM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
I didnt disconnect the battery. but I didnt turn the ignition. follow these install steps they are awesome once complete THEN turn the key, you turn it early you better get a pst2. You wont have an airbag light.
-Suman
heres the links:
http://members.aol.com/ericbosco/gt3/page_01.htm
http://gallery.rennlist.com/gallery/albuq41
good luck. It doesnt take long at all. Just make sure you have the right tool bit to unscrew the bolts from the stock seat. Its a flaring star bolt dont know the type.... Anyone know the type?
Old Dec 3, 2006 | 07:02 PM
Red 9's Avatar
Red 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond repute
Any other issues to install to consider?
Old Dec 3, 2006 | 08:05 PM
PCJR's Avatar
PCJR is a splendid one to beholdPCJR is a splendid one to beholdPCJR is a splendid one to beholdPCJR is a splendid one to beholdPCJR is a splendid one to beholdPCJR is a splendid one to beholdPCJR is a splendid one to behold
Be careful not to scrape the body sills with the seat tracks. After you have taken out all of the bolts, center the seat on the tracks. Then disconnects as asdvised above. Get the Brey-Krause replacement brackets if you are adverse to sitting at a 90 degree angle.
Old Dec 4, 2006 | 08:51 AM
live2shift's Avatar
Great tips all and nice links Suman thanks mucho!
Old May 22, 2009 | 07:25 AM
waymegelli's Avatar
waymegelli is a jewel in the roughwaymegelli is a jewel in the roughwaymegelli is a jewel in the roughwaymegelli is a jewel in the rough
Am I too late?
I installed some GT3 seats earlier this week and everything went very smoothly - I even got the seatbelt wire connected correctly. Unfortunately, I didn't find this thread until I was finished and I got the Airbag Failure light. I now know I should have disconnected the battery during the install, but I didn't. Am I forever screwed or can it be fixed somehow?
Old May 22, 2009 | 08:21 AM
maxwell's Avatar
maxwell is a jewel in the roughmaxwell is a jewel in the roughmaxwell is a jewel in the rough
no worries....the dealer can reset it for you.
Old May 22, 2009 | 09:07 AM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
You might also find this link helpful. I took the photos when I did he installation.
http://quattro.me.uiuc.edu/~jon/Pors...Seats+Rollbar/
Jon
riozilla
Aug 21, 2015 11:34 PM
TrackOne
Aug 20, 2015 12:56 PM
Vrseis
Aug 20, 2015 07:41 AM
pwdrhound
Aug 20, 2015 05:54 AM
