Storing my 996TT - Please Help!
Old Dec 11, 2006 | 10:27 AM
Hungry4$$$'s Avatar
Hungry4$$$ is infamous around these parts
My 2001 996TT has been stored for the last 2 months and I was curious to know how long the tires will be ok if the car doesn’t move. Also, the battery is connected to the charger but I’d be interested to know about any other issues that I should consider re long-term storage.
Thanks in advance!
Michael
Old Dec 11, 2006 | 01:23 PM
cpu77's Avatar
cpu77 is infamous around these parts
Me too. Funny I just started dropping my insurance on the cars I don't drive to storage. I am saving a BLOODY fortune! I can not believe I have been so stupid!
Old Dec 11, 2006 | 05:12 PM
maxwell's Avatar
maxwell is a jewel in the roughmaxwell is a jewel in the roughmaxwell is a jewel in the rough
Your tires are going to be a little flat-spotted after 2 months. Not that bad. Nothing a day of driving wont work out. I used to use mine once a month in the winter, and it was fine. It was definitely a little "hesitant" for the first 10-20 mins.
Old Dec 11, 2006 | 05:15 PM
Ken's Avatar
Ken
Ken is a jewel in the roughKen is a jewel in the roughKen is a jewel in the roughKen is a jewel in the rough
How humid is it? And do rodents have access to the space (have had major wire done by rats).
Old Dec 11, 2006 | 05:25 PM
Me_qwkr's Avatar
Me_qwkr is infamous around these parts
Things to think about..
1. battery : 2 months and its dead.. will need a jump for sures almost
2. Tires : going flat... a great way is put it on stands.
3. oil : I would be very smooth when starting her back up as most of the oil will just sit there and dry spots will occur. I THINK
Old Dec 11, 2006 | 05:43 PM
trozenhorse's Avatar
Member
trozenhorse is infamous around these parts
being from montreal my car has been stored each year for the past 4 years, this is what the dealer recommends
full tank gaz, super of course
fresh oil change
50 lbs pressure in all tires to avoid those flat spots
trickle battery charger maintainer
leave the windows open a bit
cover car and cover the exhaust pipes so no rodents get in
i add the following
fresh leather treatment on all surfaces
leave the car super clean with premium spray detailer
i start my car every month drive it around the garage it is in and close it back up. Never had an issue so far
Old Dec 11, 2006 | 05:53 PM
wross996TT's Avatar
Old Dec 11, 2006 | 06:20 PM
dtmarsh's Avatar
dtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud of
Is there any difference between a battery maintainer and a trickle charger? or are they the same thing?
Old Dec 11, 2006 | 06:39 PM
Member
there is a combo unit you can get that does both or just a maintainer, if i am not mistaken
Old Dec 11, 2006 | 10:19 PM
WyattH's Avatar
WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !
Maybe some Sea-Foam to stabilize the gas in the tank? Not sure if that's necessary or not with only 2 months of storage.
Old Dec 11, 2006 | 10:45 PM
devious996TT's Avatar
devious996TT is infamous around these parts
hmm.. i guess after reading over at rennlist.. starting the engine every 3 weeks is a bad thing to do... i guess i'll just let it sit there for 3 months... maybe i'll roll the car in the garage without starting it preventing it from getting flat spots on the tires... and i forgot to change the oil.. oops...
ryan
Old Dec 11, 2006 | 10:55 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
use to have alot of cars in storage years not months... fuel leaks were the scariest.... breaks were a surprise one i pulled tthe plugs and squaeted a little oil in each before starting.... if you can start the car once a month and let it run 30 min or so get the fluids moveing.... not good to leave tthe pistons settin in one p;ace for a year or so
Old Dec 11, 2006 | 10:57 PM
oppps forgoooooot to test read well hell i can't spell away buut have spell check
Old Dec 11, 2006 | 11:01 PM
you're a funny man steve!..
Old Dec 13, 2006 | 11:34 PM
gtr's Avatar
gtr
gtr has a spectacular aura aboutgtr has a spectacular aura aboutgtr has a spectacular aura about
The dealer told me to be sure to press the lock button so the vehical goes to sleep mode. If not in sleep mode the battery may die in 2-3 weeks. Is this true?
