How Can I Keep The Gt2 Tail Up?
Old May 3, 2007 | 07:24 PM
hkdude's Avatar
hkdude is infamous around these parts
Originally Posted by PorschePhd
Correct. Once you do that it should be good to go.
ok at the risk of sounding really stupid but jumping the wires mean connecting the two right? I did that and did a continuity test. Still I have the Spoiler Failure Control light when I first start the car. Is that to be expected?
Old May 4, 2007 | 07:18 PM
hkdude's Avatar
Phd, any thoughts? much appreciated. thanks
Old May 4, 2007 | 11:55 PM
ROCK's Avatar
ROCK is just really niceROCK is just really niceROCK is just really niceROCK is just really niceROCK is just really nice
Billystang, leave the thing down all the time !!! It looks much much better IMHO.
Old May 8, 2007 | 07:17 PM
hkdude's Avatar
Put is all the way up and wire it this way.
Unplug the harness on the right side of the engine deck.
If you look at the harness from the rear, with the lock at the top;
start at the bottom row.
thick brown and thick black = fan motor
next to them a thin red/blue and brown/red =lamp
next is a single thin wire for brake light power
top row; BLANK, then first is a single wire for the brake light(signal), next a green gray spoiler switch wire, next yellow/green thick spoiler motor (positive) , next thin gray/brown spoiler switch, last thick green/blue (ground)spoiler motor.
Unplug the thick green/blue, by pulling it out of the harness (ground for motor)
jump the spoiler switch wire, thin gray/brown with a spoiler power thick yellow/green. did it by using a paper clip
No light no hot spoiler motor wires
Good luck.
I figured it out and thought I update just in case anyone else needs it. For the down position you need to jump the green/gray wire with the green/blue wire.
Old May 10, 2007 | 10:02 AM
Kato's Avatar
Kato is just really niceKato is just really niceKato is just really niceKato is just really niceKato is just really nice
awesome, thanks!
Lucid Moment
Sep 11, 2015 09:30 PM
ECS Tuning - VW
Sep 8, 2015 08:29 AM
