Radical new transmission
Old Feb 19, 2004 | 08:03 PM
Bob M's Avatar
Bob M is infamous around these parts
Came across an interesting article in "Racecar Engineering." Apparently a UK company has developed a new transmission called the "ZeroShift" that allows for gear changes to be made "not only without cutting the engines power, but also without breaking drive to the road." It is not a sequential shift transmission but something apparently very radically new. So far they have tested it on a TVR Cerbera with good results. This magazine was so taken with it, that they said ... "ZeroShift has the potential to revolutionise automotive transmissions to the point where, putting our necks on the line here, it is resonable to expect that in 10 years time every car in the world will be built with a gearbox operating on the ZeroShift principal." If anyone is interested in reading the artical, it is in the February edition. It is complete with graphs showing Longitudinal g force comparisons, Longitudinal acceleration during upshifts and engine speeds and acceleration during upshifts. It sounds like a great transmission. Chad ... how about it. You want to be the first to put it into a TT?
Old Feb 19, 2004 | 08:36 PM
W8MM's Avatar
Honored Member
W8MM is infamous around these parts
Old Feb 19, 2004 | 08:56 PM
cjv's Avatar
cjv
Moderator
Bob,
Is that a free offer to test? If so, the answer is yes.
Old Feb 19, 2004 | 11:08 PM
ebaker's Avatar
ebaker is infamous around these parts
They don't explain how it works.
Old Feb 20, 2004 | 09:00 AM
maxiter's Avatar
maxiter is infamous around these parts
I'll go out on a limb here. I think their zero shift time is accurate because the car never shifts. It's gotta be a CVT design (Continuously Variable Transmission). In regards to the CVT design, there's lots of reference material.
Old Feb 20, 2004 | 09:29 AM
Joe Weinstein's Avatar
No, the article specifically says it can be applied as a modification
to a standard transmission, like a Borg Warner, and that the
gearbox's gears are retained . It can't be a CVT. It is just
something that changes gears without losing torque transfer.
Old Feb 20, 2004 | 09:38 AM
maxiter's Avatar
Even if there is some mechanical trickery in play that allows the next gear to be presynced and engaged at the exact moment the current gear is disengaged (I can see this as possible), there is still a measurable period of time where the engine must transition from high RPM to lower RPM. That won't happen instantaneously.
That inavoidable transition is still suboptimal, although I'll admit that if they indeed to have this mechanical trickery working, it does represent a very notable advantage over "typical" means of shifting.
Call me a skeptic, but that's my neophyte's take on it.
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
dr bit
Oct 12, 2015 09:05 AM
007 Vantage
Oct 8, 2015 08:35 PM
panas001
Sep 27, 2015 02:51 PM
