Battery Help Needed Please Read
Old Mar 25, 2007 | 07:29 PM
tweety's Avatar
tweety is infamous around these parts
Originally Posted by Red Devil
Replaced my battery today with the Group 49 Die Hard. Their computer only lists Carrera 4 but under that it shows 3.6 Turbo as the engine . Anyway, it lists Group 48 & 49 as being acceptable sizes. They are both the same width as stock and the 49 is a little longer with the 48 being a little shorter. The battery tray has adjustments for different widths and the 49 went in there easy. The only thing I had to do was put my own nut and bolt in there to tighten the battery-retaining clamp. Apparently, only 3 of the 4 holes have built in threads for the bolt that holds the clamp down and i had to use the 4th (widest) hole. In order to get my bolt under the tray I had to remove the tray with the 4 nuts that are right there. Slip the bolt under before securing the tray back (the nut can't fall due to sheet metal under it) and re-tighten the tray bolts. Drop the battery in and then just put a nut on the top of the bolt to hold the clamp so the battery couldn't slide. Reconnect vent tube & terminals and you are good to go. It starts up so fast now and I think I might have gained 50 HP
Today I had the car go flat on me and like your post here, the battery that they gave me was longer than the stocker. It fit the tray great but that last home didn't have a thread.
Now I was questioning the battery choice until I read you stating it was a 49. My battery that they gave me was from a shop called NTB which sells Sears and Exide brands. I was given the Exide version.
It says on the side label next to the cranking amps that it is a type 40 but the primary label on the battery says 49-60.
I have a base 996 and I watched the dude type in my car information so it was selecting the right machine. Is this the size made for all normal machines? I saw on his screen that the GT has a different battery selection.
Old Mar 25, 2007 | 10:58 PM
Ken7258's Avatar
Ken7258 is a jewel in the roughKen7258 is a jewel in the roughKen7258 is a jewel in the roughKen7258 is a jewel in the rough
I bought one those Interstate batteries last week. I weighed both my oem Porsche battery and the Interstate. It weighed more then 10 pounds less the the Porsche battery. I don't think the Optima battery is much lighter and the Interstate is a direct replacement without the hassle of having to buy or make a tiedown plate for the Optima.
Ken
Old Sep 9, 2007 | 07:36 PM
Yoshinoya's Avatar
Yoshinoya is infamous around these parts
Hi guys, stupid question, I know the vent tube is connected to the battery, but what is the other end connected to??? Thanks for your help!
Old Sep 9, 2007 | 09:18 PM
dublinoh's Avatar
dublinoh is infamous around these partsdublinoh is infamous around these parts
I think it just vents to the ground
Old Sep 9, 2007 | 10:16 PM
Yoshinoya's Avatar
Thanks Dublinoh!
Old May 17, 2008 | 07:48 AM
BostonCarrera4S's Avatar
BostonCarrera4S is just really niceBostonCarrera4S is just really niceBostonCarrera4S is just really niceBostonCarrera4S is just really nice
Did you need a vent kit to reconnect the vent tube? I'm going to replace my battery with an interstate MTP-93 which is a group 49 battery. I read that it is a direct fit but I am unsure about the vent tube.
Old May 17, 2008 | 07:52 AM
Did you have any problems with the vent tube when you installed your battery? I'm picking up my interstate battery today.
Ken
VGLNTE1
Aug 24, 2015 12:23 PM
00aston
Aug 24, 2015 09:29 AM
DSCOFF
Aug 23, 2015 01:22 PM
Fadi
Aug 21, 2015 03:43 AM
