Can I run GT2 sized tires on my stock 18" TT rims?
Old Feb 25, 2004 | 02:04 PM
John in Norcal's Avatar
John in Norcal is a splendid one to beholdJohn in Norcal is a splendid one to beholdJohn in Norcal is a splendid one to beholdJohn in Norcal is a splendid one to beholdJohn in Norcal is a splendid one to beholdJohn in Norcal is a splendid one to beholdJohn in Norcal is a splendid one to behold
Can I run 235/40/18 front and 315/30/18 rear tires on my stock rims instead of the standard 225/40 and 295/30 on the TT? I figure more tire equals more traction.
Do I sacrifice anything with this setup? Would I have to roll the fenders due to the increased height and width of the tires? I am curious to know if anyone here has done this.
Old Feb 25, 2004 | 02:30 PM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
Does the fact that the GT2's wheels are 8.5" wide (front) and 12" wide (rear) mean it's tires wouldn't work on the Turbo's wheels?
Old Feb 25, 2004 | 02:55 PM
msindi's Avatar
interesting Q...
Many here with aftermarket wheels do run 235 fronts on 8.5" wide wheels and 315 on 11" wide rears...
Old Feb 25, 2004 | 03:07 PM
Good point, Doc. I know a 235 width tire will fit nicely on an 8" wide rim and as msindi mentioned, many folks do run 315 rears on 11" wide rims.
I assume the speedo calibration may be slightly off due to the increased diameter of the bigger tires but who really cares! Are there other factors that may affect performance/handling with this setup?
Old Feb 25, 2004 | 03:18 PM
msindi's Avatar
only thing you wanna make sure is to look at your tires manufacturers specs and make sure that the difference in OD between front and rear (or revs per mile) figures are within 3% of each other so you dont mess up your AWD viscous coupling...
Note that calculating OD using the numbers on the tire is NOT good enough as a 315/25 19 has different OD depending on manufacturer...
Old Feb 25, 2004 | 03:25 PM
rmrmd1956's Avatar
rmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of light
I'm doing it now. No issues, no rubbing. I'm using pilot sport tires.
Old Feb 25, 2004 | 03:29 PM
That's what I wanted to hear. Do you feel any improvement in traction and handling compared to the stock setup?
Since you say 'no rubbing', is your car lowered?
Old Feb 25, 2004 | 03:33 PM
I I do this, I plan to use Pilot Sport N-rated OE tires for the GT2, so it shouldn't be a problem. Thanks.
Old Feb 25, 2004 | 07:27 PM
Under PSI's Avatar
Under PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud of
Do you have pictures?
Old Feb 26, 2004 | 01:09 PM
rmrmd1956's Avatar
tires
car handles like on rails.
pictures on my website
Old Feb 26, 2004 | 02:44 PM
Jack(LA)'s Avatar
Moderator
Jack(LA) is infamous around these parts
GT2 sized Michelin tires on Gemballa wheels (8.5" front, 11" rear) with a slightly more aggressive offset than stock -- no rubbing issues.....
The_Ruski_Driver
Oct 25, 2015 08:40 PM
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
ModBargains
Aug 20, 2015 12:28 PM
Aug 19, 2015 06:35 PM
oddjob142
Aug 19, 2015 12:27 PM
