Zeitronix - Installed today!
Old Jan 12, 2007 | 11:55 PM
AzExoticLover's Avatar
AzExoticLover is infamous around these partsAzExoticLover is infamous around these parts
Originally Posted by John D II
Dave,
I have a few questions regarding your install.
Were you able to take the boost signal from the line running to the Greddy unit or did you have to run a dedicated line?
Did you weld bungs on your exhaust for the wideband O2 sensors or take the signal fron the factory O2 sensors?
Did you pick up an AFR signal from both sides (and use the programable spare user input for the second side reading)?
Did you mount EGT sensors on both headers?
Good questions, I will awnser the ones I know and talk with the Install Shop tomorrow for the rest of the awnsers.
1 - We ran a seperate dedicated line for the boost
2 - I dont know for sure, BUT I think he welded it into the exhaust. I will double check and let you know
3 - Yes, picked up the AFR signal from both sides
4 - I think he only did the EGT in 1 header but will find out for sure tomorrow.
Dave
Old Jan 12, 2007 | 11:56 PM
Kevin,
I was under the impression that the exhaust bungs are for AFR O2 sensors and EGT is taken by tapping the headers with a temp probe.
I think you are right! I will double check although....
Old Jan 13, 2007 | 12:13 AM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
Dave,
Also, could you find out where they mounted the AFR exhaust bungs in relation to the stock O2 sensor bungs? And did they use extended bungs or standard length?
Old Jan 13, 2007 | 12:39 AM
iLLM3's Avatar
Kevin,
Exactamundo!!!!
Dave nice setup man, let us know how you like it
Old Jan 13, 2007 | 01:50 AM
RT7's Avatar
RT7
Show-N-Go like J-Lo Mofo
RT7 is infamous around these parts
Cool setup Dave.
Old Jan 13, 2007 | 03:04 AM
Jean's Avatar
Jean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond repute
A Must have.
Old Jan 13, 2007 | 06:31 AM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Kevin,
John, I was under the same impression until I went to the dyno and found out they are much too small to be a wideband O2 plug...when I get home tonight I will take a pic of my new EP which has both bungs on one side and you can see the relative sizes.Kevin
Old Jan 13, 2007 | 02:50 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
Looks like they did an awesome instal...... Is it not centered in your dash though?.... I think that would drive me insane lol
Old Jan 13, 2007 | 03:15 PM
Yeah, I know... Its off center becuase the LED Light/Buzzer unit is to the left of it. I wanted them mounted together in the same plate.... Look really close and you will see the small LED the left of the unit. The Light/Buzzer boxis about 1 inch x 1 inch....
Dave
Old Jan 13, 2007 | 06:14 PM
buddyg's Avatar
Looks sweet! Except I didn't need to see those nasty feet! j/k
Old Jan 13, 2007 | 06:47 PM
NAPO's Avatar
NAPO is a splendid one to beholdNAPO is a splendid one to beholdNAPO is a splendid one to beholdNAPO is a splendid one to beholdNAPO is a splendid one to beholdNAPO is a splendid one to behold
Very nice setup, they did a great job on the install.
Old Jan 13, 2007 | 06:51 PM
I know, I have some big *** feet.....
Old Jan 13, 2007 | 07:14 PM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
Originally Posted by MARKSKI
I didnt know.... but looks great anyways....
KPG and I were talking about it today via fone... I guess u will be our ginny pig...
J/K
mark
Do I get no credit for having this thing for over a year now and you guys ignoring me when I pimped it???
Old Jan 13, 2007 | 07:17 PM
Dave
Are you sure your installer picked up the AFR from both sides? As the unit comes, it inludes one EGT sensor and one AFR sensor. I had one mounted on the left bank and one mounted on the right.
They said you could run two AFR's but it would require two sensors and a toggle switch to switch between the two as you can't monitor both at the same time. Like I said, I mounted my AFR on one side and my EGT on the other so I could tell if one portion of the engine went completely out of whack. You get used to what is "normal" as you look at it for a while.
Old Jan 13, 2007 | 07:19 PM
cpu77's Avatar
cpu77 is infamous around these parts
Its just the flash! The unit and bezel look great in daylight or without a flash... It was just to dark tonight to take a pic without the flash.....
I mean no disrespect. It just looked funny, have any pictures with out the flash?
