Mod Problems - Anyone Have a Suggestion?
Old Jan 17, 2007 | 09:11 AM
tx turbo's Avatar
Awaiting Email Confirmation
tx turbo is infamous around these parts
thanks guys. i will clean the maf today and let you know what happens.
Old Jan 17, 2007 | 09:44 AM
WOODTSTER's Avatar
Get the code read and see how many cylinders are misfiring.
If it is 4-6 cylinders misfiring, then it is plugs, Obviously AWE has #6's in there.
If it is 1-2 cylinders, my guess is it is the coil packs (there is one for each cylinder)
MK
Old Jan 17, 2007 | 03:00 PM
George@Revo's Avatar
George@Revo is infamous around these parts
Originally Posted by tx turbo
around 5000 rpm it starts breaking up and is not smooth.
I see this from time to time and many times it's coilpacks. Do you expreience this issue when the car is in 'stock' mode? I would agree with WOODSTER, have the dealer scan for codes with their PIWIS. They can also confirm the output voltage and duty cycle under load wich will also help determine if it's CP's.
Old Jan 17, 2007 | 03:52 PM
K24madness's Avatar
K24madness is infamous around these parts
What did you gap the plugs at???
It is the plug gap causing the problem. Try setting them at 30 thou
PV=nRT.
Sep 9, 2022 06:06 PM
cadamson
Oct 6, 2015 02:06 PM
cm09578
Sep 22, 2015 06:07 AM
vr6tee
Aug 29, 2015 03:52 AM
rnl
Aug 26, 2015 02:36 PM
