When to change plugs?
Old Jan 14, 2007 | 12:08 PM
AzExoticLover's Avatar
AzExoticLover is infamous around these partsAzExoticLover is infamous around these parts
How often are you guys changing your plugs?
When boosting 1.3 Bar and higher, should the plugs be changed more often?
Old Jan 14, 2007 | 12:13 PM
Garey Cooper's Avatar
Garey Cooper is infamous around these parts
My car is now just over 28K miles; a 2001. I've changed plugs twice.....first time around 15K miles. This last time I had the 30K mile service done at GMG; a sponsor on this board. They also recommended and used the upgraded heat range plugs, I can't recall the spec/name but it's been discussed on the board.
On a high-boost (or nearly any turbo car) the short answer is; yes, change them more frequently.
Old Jan 14, 2007 | 03:10 PM
Joe Weinstein's Avatar
And it's not a trivial job, so also consider changing the plugs
whenever the car is being worked on in a way that you've
already done most of the work to expose them.
Joe
Old Jan 14, 2007 | 03:15 PM
+1 JOE....
yes... and Dave... In ur case.. when u feel the misfire... or I say between 5 and 10 K miles.....
once a years for sure...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jan 14, 2007 | 05:16 PM
WOODTSTER's Avatar
2001's (like mine) came with Beru #5's which do not tolerate high boost well.
Now Porsche spec for all years is the #6. Several brands are used. The
ones you get from your Porsche dealer seem fine. Others like the Bosch.
MK
Old Jan 14, 2007 | 05:58 PM
Originally Posted by MARKSKI
+1 JOE....
I hear you... I purchased the ones we talked about, now I just need to have them put in next week sometime!
COBB Tuning
Jan 1, 2025 09:02 AM
away
Sep 4, 2015 12:30 PM
LiquidElephant
Aug 27, 2015 06:17 PM
00aston
Aug 27, 2015 12:01 AM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
