Battery Replacement
Old Jan 24, 2007 | 09:58 PM
Hoppity's Avatar
Hoppity is a name known to allHoppity is a name known to allHoppity is a name known to allHoppity is a name known to allHoppity is a name known to allHoppity is a name known to all
Battery Replacement
I have an 02 Turbo and I got a new battery from Checker but its slightly longer than stock battery so the bolt to hold it in the tray doesn't fit. Is there any place besides the dealer to get the correct sized battery?
Old Jan 24, 2007 | 10:30 PM
Turbohead's Avatar
Turbohead is just really niceTurbohead is just really niceTurbohead is just really niceTurbohead is just really nice
I had same problem with interstate and duralast.
Costco has a kirkland for 996 that fits....... cheap too.
Old Jan 25, 2007 | 07:04 AM
Red Devil's Avatar
Red Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to all
I just replaced mine one month ago with a slightly bigger one from Sears. All you have to do is get a nut/bolt combo similar in thickness to the stock bolt that threads into the body. If you take the battery tray out with 4 nuts, you will see there are 3 holes that accept the stock bolt to secure the metal clip for the passenger side of the battery. There is one more hole which is unthreaded but if you put the bolt up through that hole before securing the battery tray back in, the clip should line up well for the larger battery. All you have to do then is put the nut on the part of the bolt that now sticks up through the tray and the clip.
Old Jan 25, 2007 | 08:11 AM
cpu77's Avatar
cpu77 is infamous around these parts
Anyone make a kit to run a red top or yellow top battery?
Old Jan 25, 2007 | 08:57 AM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
Im running a yellow top! GMGracing.com has a tray mount but your best bet is to take the tray under the battery out and directly mount the yellow top battery to the existing tray. GMG charged 275 or soemthign for that tray whihc is rediculous IMO
-Suman
pwdrhound
Sep 16, 2021 02:27 PM
Jul 29, 2019 11:13 AM
DetomasoGTS74
Nov 11, 2015 09:01 AM
OldBoldPilot
Aug 24, 2015 04:00 PM
DSCOFF
Aug 23, 2015 01:22 PM
