Easy or Dangerous Battery Charge?
Old Feb 1, 2007 | 08:01 AM
YNOTFAST's Avatar
YNOTFAST has a spectacular aura aboutYNOTFAST has a spectacular aura aboutYNOTFAST has a spectacular aura about
I read in the manual that we can access the positive terminal of the battery remotely in the fuse box by clamping a jumper cable there and the negative cable on the driver's door latch striker. This was for an emergency unlocking with a dead battery on the 996TT.
My question is can I use the fuse box terminal and driver's door latch stiker to safely hook up a smart battery charger like a BatteryTender?
Will it work to keep my battery charged and is it dangerous or foolish to do so?
Thanks.
Old Feb 1, 2007 | 09:16 AM
tom kerr's Avatar
get the porsche or similar charger that just plugs into the cig lighter. Way easier!!
Old Feb 1, 2007 | 10:06 AM
YNOTFAST's Avatar
Yes, the cig charger is easier, but I already own several BatteryTenders and would rather not have to buy more chargers if I don't need to.
Old Feb 1, 2007 | 12:55 PM
tom kerr's Avatar
then your way will work but dangerous I dont know!
Old Feb 1, 2007 | 01:34 PM
Alpha's Avatar
Alpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud ofAlpha has much to be proud of
Maybe you could buy a cig lighter adapter for one of your existing battery tenders (maybe about $10?)? It would be way more convenient, and maybe safer too.
Old Feb 1, 2007 | 02:04 PM
mose55's Avatar
mose55 is infamous around these parts
Just by the cig adapter and splice it to your Tender versus wires and clamps all over the place. I find that for me, this kinda stuff needs to be as simple as possible or else I never use it. I have the OEM cig trickle charger and plug it in if I think I will not be using the car for a couple weeks.
Old Feb 1, 2007 | 05:12 PM
YNOTFAST's Avatar
Thanks to all. After some thought (something I should have done earlier) I realize I'd have to leave the drivers door open to connect the charger to the door latch striker for ground. And that would mean my door has to stay open, and that would mean the lights are on drawing current from the battery that I am trying to charge. So I guess it's time to stuff something into the old cig lighter and pump up the currents. Thanks all.
Old Feb 1, 2007 | 05:31 PM
jimdarcy's Avatar
jimdarcy is infamous around these parts
Members on this board have raved about the Black and Decker tender
http://www.amazon.com/Decker-VEC080B.../dp/B000EJTI7I
Old Feb 5, 2007 | 09:35 PM
YNOTFAST's Avatar
JimDarcy;
Thanks. Looks interesting. I have seen other versions of this but not with the cig lighter plug.
Old Feb 5, 2007 | 10:52 PM
rcalcaide's Avatar
rcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud ofrcalcaide has much to be proud of
Check the Sears website. they have a battery tender/charger for 30.00 bucks that can also plug into the cig lighter. also comes with a 3 year warranty.
http://www.sears.com/sr/javasr/produ...AUTO&ihtoken=1
Old Feb 6, 2007 | 12:54 PM
YNOTFAST's Avatar
rcalcaide
Just checked and they are temporarily out of stock. Looks like a good and inexpensive unit. Thanks.
Old Feb 6, 2007 | 01:32 PM
rosesplus's Avatar
rosesplus is infamous around these parts
Walmarts got one called DieHard which I've been using and is great. Plugs into the cigarette and turns off/on by itself. $24.95
Old Feb 6, 2007 | 01:54 PM
chinitowest's Avatar
chinitowest has a spectacular aura aboutchinitowest has a spectacular aura about
Thanks fo rthe info. I'm gonna check it out!
Old Feb 7, 2007 | 03:21 PM
rcalcaide's Avatar
Hey everyone,
I just picked this up at Walmart for 18bucks. cant beat that!
http://www.blackanddecker.com/Produc...roductID=15572
Old Feb 7, 2007 | 10:28 PM
TJMONEY's Avatar
TJMONEY is infamous around these parts
Im definately gona have to go to Sears or Wally world to get one of these chargers. Thanks for the info!
proTUNING Freaks
Sep 15, 2015 07:28 AM
gadgetman
Sep 10, 2015 03:29 PM
oo7
Sep 10, 2015 08:08 AM
lokmeup
Sep 9, 2015 09:24 PM
katyrow
Sep 7, 2015 10:17 AM
