A quick note for guys with Moton's/JRZ's
As I learned today after getting the leaky hose on my front JRZ repaired: Don't tie the hose to the A-arm when mounting your Moton's/JRZ's. You will eventually end up ripping the hose apart and cause the oil to leak out and ultimately break the dampers. Definitely consult an expert on the proper way of running those lines so to save yourself the cost of a rebuild later.
